Question about Whirlpool Refrigerators
Whirlpool gold refrigerator compressor clicks on for about 5 seconds then back off. The fan next to it was blocked when I opened the access panel. Unblocked it and it 3 hours ago and still has the the problem.
    Scholar:
  • 50 Answers
It's either the compressor start relay/ overload, or the compressor itself. If the fan wasn't running, the compressor would have got very hot and potentially damaged it. Sometimes you can tell if it's just the relay by taking it off and shaking it. If you can hear peices rattling around, it's a bad relay. If not you'll need to check the compressor. When you take the relay off, you'll see 3 pins. Use an ohm meter to make 3 readings. One will check the start winding, one the run winding and the third will check both. All 3 should be between 3 and 13 ohms. If any read infinite you've got a bad compressor. Then check each of the 3 pins to ground. If you read anything other than infinite you've got a bad compressor. Even if the readings are ok, you could still have a locked up compressor. You'll have to put on a new relay and if it still won't run you'll need a new compressor.
Posted on Jul 20, 2008
I have a 2004 Whirlpool gold model #GD5RHA 25.4 CF refrigerator. It has stopped cooling (both freezer and refrigerator). The evaporator fan inside the freezer operates but the evaporator coil are not
go to a refrigeration supplier and buy a 3 in 1 kit meaning relay, capacitor and overload in one unit just follow the print in the unit and it should start after you plug it back to the wall make sure you disconnect before working on this unit let me know what happens. nice picture and very helpful for me.
Dec 31, 2014 | Whirlpool Refrigerators
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
I have a Whirlpool Gold side by side refrigerator/freezer. It is 6 years old. Model # GS6SHAXML00. When I opened the freezer tonight, the ice was melted and all the contents were no longer frozen. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
heatman101
Sep 26, 2010 | Whirlpool Gold® GC5NHAXST
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
My whirlpool fridge is hot, took the cover off of the coils inside freezer, look ok. Took back cover off of the back and the compressor is hot
Hi jason;
Shall take it that you have a Side by Side setup? If so with rear cover off, when you start it does the cooling fan come on beside compressor? Also remove front grille and clean front condensor coils, full dust and hair all problems can happen. (like blocking of car radiator). Try these if fan doesn't work, replace.
Mar 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest Gold White Model# - GS6SHAXLQ03
The relay is the start device,but you need to determine if you need it,try to see if you have power to the compressor,is the compressor running,is the condenser fan motor running,is the coil under the unit clogged with dust,if the fan under the unit doesn't run it will overheat the compressor and it will go off. and if the coil is clogged the same thing goes.
 Usually if the relay is bad the compressor will make a hum and a click noise but will not actually run.about every 5 minutes..
Sep 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side
if the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side GS6SHEXNQ00
Hi. You either have a dust blocked condenser coil or your condenser fan motor has stopped. It is located next to the compressor. If the motor has failed, put a fan in the back of your refrigerator and let it blow into the back of the refrigerator until you get a fan motor. Make sure you leave the compartment cover off the back of your refrigerator. Your compressor is super hot now and the start device relay is getting hot and may fail if the situation isn't resolved soon. I would get a new start device relay for the compressor also to prevent future failure. The reason for the hot areas is because the freon is not being cooled and there is freon tubing located inside the cabinet where you are touching. Please check my items on Ebay as username themackshack. Good Luck, Mack
Jan 15, 2008 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
