Question about Technics SL-1210 Turntable
Drive speed I recently shipped my 1210 and it may have taken a knock, I doubt it, however, when the turntable is on the pitch drops at exactly the same time so that the red dots under the illuminated red light jump. It is exactly at the same time in each and every 360 degree revolution of the turntable. Is it the belt? Magnet?
  • 515 Answers
There are no belts in the 1210 turntable. It is all driven by various Integrated Circuits (IC). These IC's tend to go bad over time. Unfortunately, it's not an easy fix, and you'll have to take it to an authorized service center for servicing.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 23, 2008
Erratic pitch movement
I'm afraid it could be many things, most likely nothing to do with the pitch control. I believe you have a Direct Drive motor, so that maybe bad. There is a circuit that operates with a microprocessor(computer) IC, called a Phase Lock Loop, which is what keeps the pitch accurate. Anything there could be bad. More more information, or should you have more questions, please visit my website at audioserviceclinic.com. I may be contacted through the website. Thank you.
Dec 17, 2013 | Technics SL-1210 Turntable
Pitch wobble 1210
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Apr 23, 2010 | Technics SL-1210 Turntable
1210 mk2 speeds up on its own
hi ,,,the pitch control is good dont chance it ..you have a problem on the main board ...of your turntable...check the cold solder of your main board of your deck....maybe some of them are loose that why you got a wiggle platter.. u...then fidbk me wat happend? u
Jun 18, 2009 | Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technis 1210
The pitch controls are probably dirty and need to be calibrated. Any authorized Technics service center should be able to do this fairly easily. You can clean them out yourself by using DEOX-IT or similar, but would need a frequency counter to calibrate them.
- DJPROLAB
Feb 03, 2008 | Technics SL-1210 Turntable
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
1210 mk 2 strangeness
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
Dec 01, 2007 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
- TWEAK AV LAB
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
