Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Saeco Royal Digital has steam coming out the vents and fogging the display when using the steam. How to fix this problem?
  • cheen Sep 02, 2008
    I have the display fogging up and water leaking out from under the machine after the coffee is made.
    I have been trying to locate a service manual to dismantle unit and try and find the problem
  • ushemj Sep 05, 2008
    I have exactly the same problem. Does anyone know where a workshop manual can be obtained?
  • 515 Answers
I think you have a pipe leakage.
Take of the top and see how it look inside, if you have a leak then it will go down to the power button and you will have a short circuit.
Posted on Jul 20, 2008
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
May 20, 2011 | Saeco Royal Professional Espresso Machine
I have a saeco Royal Professional and have noticed that although the steamer appears to have sufficient pressure it is taking longer to heat the milk via the wand and that it appears to be steaming up...
Very good description. The problem is very simple. Inside the machine behind the steam wand the secure nut on the pipe coming to the wand is loose and you can tight it back in place very easy. You will need to remove the top plastic cover to see where the steam is leaking.
There is a chance that the pipe or nut is proken but this is very rair.
Good Luck
Mar 27, 2010 | Saeco Royal Professional Espresso Machine
Steam building up within the unit/
The steam pipe after the steam solenoid to the steam arm is leaking which it can be cause just becase the support nut is loose. So if you just remove the top plastic panel you can even use the machine and see which point need to tight it up.
Good luck.
Remember top vote for this answer
Mar 10, 2010 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Have a saeco royal digital plus, when trying to steam milk I get a short burst of steam then lots of hot water
If you model has dual boilers then the steam boiler is damaged, if it only has a single boiler, then either the thermostat on the boiler or the cpu board the tell is to pulse steam is damaged.
Jul 16, 2009 | Saeco Royal Digital Plus Coffee...
How to purge saeco royal digital plus
run hot water from the steam nozzle for few seconds
Mar 01, 2009 | Saeco Royal Digital Plus Coffee...
The steam knob only turns 1/4 turn to left
Hi
!/4 turn is all the Magic and Royal machines will do. Don't try to turn it farther or you could break the steam valve.
Dec 26, 2008 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
The mahine does not froth the milk properly anymore
alisha165,
the saeco royal digital dosn't froth milk.... it produces steam, you are the one that froths the milk. is the machine still producing steam? if not you will need to have your steam boiler replaced. This should only be dune by a qualified repairer. If it is still producing steam but it is not as good as it use to be, descalling you machine may help.
Sep 29, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
