Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Shuts off then flashes power light
I have a panasonic PT-53WX53G, I had a convergence problem, the picture was like in blue 3d (like a blue shadow). I got 2 convergence ICs from here. You sent me instructions on how to change them. I changed them and everything seemed good. I turned the TV on adjusted the convergence and was like new. Now after a day all of a sudden the TV turned off and the power light flashes 3 times pause then 3 more and so on. If i unplug the power coard the plug in back in, then the TV turns back on fine. works good for about 20 minutes then does it again. Can anybody help me with this problem?
  • 4 more comments
  • Scott Lucero Jul 20, 2008
    there are 6 large capacitors by the flyback transformer way in the back of the tv where the pwer supply coard comes in. they dont seem bulged or discolored. there is white rubbery stuff on the sides of each capacitor. it doesnt seem like it came out of the cap. is it supposed to be there or is that my problem. if it is can you help buy the right ones?
  • Scott Lucero Jul 29, 2008
    The TV shuts off when i turn it on. It makes a buzzzzing sound for a few seconds, the sound starts to come on then goes off with kinda a loud shreeking sound. then power light flashes 3 times.
  • Scott Lucero Jul 30, 2008
    I replaced the ICs with the exact same part number that was in it stk392-110. and now i just changed the flyback transformer because i thought i might have messes it up when i pulled the 2 red wires out of it. but that did nothing it still does exactly the same thing.
  • Scott Lucero Aug 10, 2008
    ill try those caps, is there anyway you can help get those ordered, which ones i need.
    i dont know what the heck you are talkig about, but i never rated that answer! So im not insulting you, but ewww oh well
    I am not ungrateful, i was very grateful for ur advice, i did not know if it was correct yet, i would have at least gave it a helpful, but it never even asked me to rate it, my original question i rated fix ya. there was another answer on here for a little while then it was gone. it was not from you. but i stiil never was asked to rate anything. the only time i was asked to rate was on the very first question. i rated fixya. i paid for this advise so dont act like ur going out of ur way, u dont even know its right answer anyway.
  • 3,037 Answers
You have a short, most likely in the convergence circuit. Try replacing the convergence ICs first and let me know how that goes
good luck
Posted on Jul 30, 2008
  • Benjamin Patri
    Benjamin Patri Jul 30, 2008
    Oh, I see that you already replaced the ICs, sorry, there still is a short in the convergence circuitry that needs to be found though and fixed
  • 2,326 Answers
Have you done any hand soldering prior to install the ICs?
I would suggest to double check the solder joints again using a magnification aid of 2X or 4X.
If all the solder joints look properly solder, I would also inspect any other solder joint around the high power resistors near the STK ICs.
The next question is if you apply thermal compound before installing the ICs.
  • 10,594 Answers
Are you sure that covergence ICs are same number and description ? In my openion, you installed compatible number ICs insteed of Original part and this is the cause of current problem in your tv.
    Scholar:
  • 101 Answers
I think this is a power problem, check the power supply for bulging or leaking electrolytic capacitors or other damaged components.
Posted on Jul 20, 2008
  • 2 more comments
  • Jerrod J
    Jerrod J Jul 20, 2008
    The white stuff is just the petroleum glue. Sometimes the capacitors will not show any visible signs of failure, is the white glue turning brown where it's touching the capacitors? It does that when the caps get really hot, and could mean a failure (although not always) The only way to be sure is to measure the ESR (equivalent series resistance) of the capacitors , which requires a special meter.
  • Jerrod J
    Jerrod J Jul 30, 2008
    I still think the problem is in the power supply, the buzzing is probably the capacitors, they can fail shorted causing massive power draw and causing an automatic shut off. Replacing all the electrolytic capacitors in the power supply would not be a bad move.
  • Jerrod J
    Jerrod J Aug 10, 2008
    "thanks for trying"? no, I dont think I will help you anymore. Good luck. Try not to insult the people who are trying to help you.
  • Jerrod J
    Yes, my solution is rated "thanks for trying (70)" We don't get paid unless it is "Helpful" or "Fixya" rating. I just get tired of ungrateful people rating working solutions below what they should be rated. I apologize if you didn't rate my solution that way, I dont know if Fixya automatically rates it like that if you don't rate it yourself, but regardless, you could have at least rated it as helpful since it is probably the correct solution. But whatever.
The color goes out on my panasonic PT-47WX49E TV.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
May 11, 2012 | Panasonic PT-47WX49 47" Rear Projection...
The blue coloring is way off center
Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 20, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Pt-51dx80a is having shadow issues, from the center top to bottom in focus no shadows. going outward right and left the shadow distance gradually increases to almost a 1/2 inch
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2011 | Panasonic PT-51SX60 51" Rear Projection...
THE PICTURE ON MY TV IS SHOWING A YELLOW SHADOW ON ON SIDE MORE & A BLUE SHADOW ON THE OTHER. IS THIS A BULB PROBLEM?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 28, 2011 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Howtofocus
Push the Flash Focus button on the tv remote don't work?Yes,the tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX53 47" Rear Projection...
The Panasonic mod# pt-47wx49e has started to have a blue and a yellow shadow on the right side of the screen. the rest of the screen is normal. The operating instructions give you diddle to on. Do you have...
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows or 3D colors pictures.The tv convergencce board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 10, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The blue lense is off by 2 inches and can't adjust it. The picture has a blue shadow.
The tv have a problem known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have 3D pictures or colors shadows.The tv convergence board it dead.Require changing 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Panasonic PT-47WXD63 47 in. Rear...
MY PT-53WX53G turns off when powered on. The
Thats the error for convergence failure. Heres a link to the repair kit for your model which contains the parts and the CD with detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jul 06, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
