Question about Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-2328 Memory upgrade
I bought two sticks at 2 g each, when I install both of them my laptop turns on but will not boot. If I only put one stick in it boots well. Is there some way that I can fix it so that it will work with both memory sticks?
  • bamaboy75 Jan 12, 2009
    my laptop is running extremly slow and playing a video from the web forget it. I used my webcam once and it never worked again.
The 5610z has a max ram of 2GB that is your issue. Check this model on crucial
Posted on Aug 11, 2008
    Genius:
  • 2,785 Answers
You both memory should have same speed and frequency and if possible from same brand, in your case check one by one if system is working fine then your frequency is not matching
Posted on Jul 23, 2008
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Memory upgrade for Acer Aspire 3680
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot so you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS hope this helps pls appreciate by rating as fixyaa.thanks and Godbless.
Jan 07, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3690-2970 Memory Upgrade
Your laptop may just not recognize and not even boot up if you exceed the memory limit. It will not harm the laptop if you give it a try with the 4gb. However, sometimes caution is a good thing. It all depends on what you are trying to do on your acer. If you haven't already, remove the old memory sticks and replace it with the 1 2gb memory stick. Work with it for a little while (this should not give you a problem). If you feel the laptop is still too slow....let me know...I will look up the compatibility with the memory and your laptop.
Nov 16, 2008 | Acer Aspire 3690-2196 Notebook
Ram Memory
I did this 2 days ago on my gf's aspire 5315-2153 (walmart special $348). the underside panel has four tiny screws which must be removed and then the fun begins. The plastic panel is large and doesn't want to be removed. After 20 minutes of cursing, i was able to get it out with two hands and a small screwdriver. The plastic panel has about 7-8 tabs which also hold it in place. The original two memory modules must be removed and the two new ones installed in their place. i bought crucial memory from newegg.com (CT2KIT12864AC667) for $17 delivered (took a week to get) which was much cheaper than buying it direct from crucial.com Save the old memory modules just in case you have a problem with the new ones. After putting them in, I restarted the computer and it booted up fine. No BIOS changes or any of that were necessary. So for $17 and about 30 minutes, this lappy is now running strong with 2gb instead of 1gb. Initial impression is that it boots up faster and shuts down faster but that is about it in terms of improvement!!!
Aug 24, 2008 | Acer Aspire 5315 Notebook
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3000 Notebook - major memory problem!!
it sounds like the memory, try removing the new memory from the notebook and see if there are any errors, if not then that stick is ok, try just your new memory in the notebook and leave out your old memory, if the same problems you know its the new memory, if there are no problems, then the two sticks wont work together.
Jun 04, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5610-4648 Notebook Logo
582 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
