Tv will not connect to dvdvideo player - Televison & Video
    Master:
  • 726 Answers
Ok tell me the exact nam of the tv and the dvd player
Posted on Jul 20, 2008
How do I get the TV to show DVD's from the attached DVD player? I have a model 27V512T or where can I buy a manual.
Hey Don, You must connect the dvd player and the tv together via the Composite connections. Your tv should have three rca connectors on the front. They be red, yellow and white. Connect the same colors to the back of your dvd player and you'll be in business.
Jan 18, 2015 | RCA Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hooked it up to a blue ray player, no cable at all, just the blue ray, and i get no sound from the tv, just a picture
To connect the Blu-ray player to the TV, connect the Video OUT of the Blu-ray player to the VIDEO 1, VIDEO 3, VIDEO 4 port on the TV using the "RED/WHITE/YELLOW" Composite cable to get both audio and video. You may also connect the "Component OUT" port of the Blu-ray Player to the VIDEO 5 and VIDEO 6 port on the TV using the (Red/Blue/Green/Red/White) Component cable to get both audio and video from it. If you have any questions on connectivity, you may wish to reply with your query.
Thanks,
Pradeep
Nov 19, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Best way to connect DVD player to TV
U have a S-video connection in ur tv right?Use that for ur Blu-Ray player.Use the RCA cable Red,White for connections for the audio.
Mar 24, 2010 | Toshiba 50H82 50" Rear Projection...
I can't turn off the Progressive Scan feature on my Sony DVP-NC85H. I tried pressing 3, 6, and 9 while the unit was off but had no success. Apparently I can't use the HDMI connection unless the Progressive...
When your player is connected thru HDMI cable it should automatically detect what your TV's display is capable of. I am assuming that you have the DVD player connected to a HD television. There should be a progressive scan button on the front of the player. But I don't think the button will work when it is connected to HDMI. How do you have the player connected? Is it directly to the TV or does it go thru a switch or a reciever then to the TV? If it is connected this way then that can be the problem. There is a signal that needs to make it to the TV and these devices can block the signal. So verify that it is connected directly to the TV and that the HDMI cable is working. If that is ok then connect another connection to the TV along with the HDMI cable also hooked up. Then change your TV's input selection to that connection. You should be able to get to the dvd menu and set the HDMI output from auto to a format that your TV will accept. Then go back to the HDMI input and see if you have a picture. Let me know if that helps.
Sep 28, 2009 | Televison & Video
Older ge tv but cable ready-no remote.... need to find channel to play dvd player on.Recently connected dvd player but can't play a dvd.The tv is connected to a cable box.
Hey wegodsky,
If you're not able to find the right channel on your TV to use your DVD player, you may want to try changing the TV's input source instead. Many TV models will require that the TV be set to an external antenna in order for any other device (like a VCR or DVD player) to function correctly. This can usually be done by pressing the menu button on the TV itself and selecting an option similar to "Input," "Source" or "Antenna" if you do not have a remote control for your TV.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
I have just purchased a Toshiba Integrated Digital LCD TV and I can't seem to run my DVD and Video player through the TV. I'm probably not connecting it right, but don't know what else to try. Thanks for...
The DVD and video player have HDMI. Component, S-Video and RCA audio/video output connections that need to be connected to the appropriate inputs on your TV. You select the type of connector and cable to use.
HDMI provides the best quality, if available and works for both audio and video.
The TV's, DVD's and video player's manuals describe how in detail. Look at the connection instructions and diagrams. You then must select the correct input on the TV to play each source.
Mar 09, 2008 | Televison & Video
Trying to connect my dvd to the tv plus i have cable
You can use the following:
TV Connections:
  1. Composite (red, white, yellow)
  2. Component (red, blue, green)
  3. HDMI -
DVD Player Connections:
  1. Composite (red, white, yellow) - comes standard.
  2. Component (red, blue, green) if you have it.
  3. HDMI - if you have it
You can use any of those to connect the dvd player to the tv. You can use the remainder to connect the satilite box.
Feb 29, 2008 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
