MY DELL VOSTRO 1500 PROBLEMS
MY LAPTOP SUDDENLY STOPS CHARGING MY LAPTOP BATERY,EVEN WHEN THE ADOPTER SEEMS TO BE FUNTIONING(THE USUAL ON GREEN LED IS ON)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
Check the Vostro 1500 battery is good or not. Then Check the adapter . Also The motherboard is the problem that can reasult " laptop battery plugging but not charged".
Posted on May 14, 2010
WHEN WIGGLED THE POWER JACK,THE CHARGING LIGHT INDICATOR FLASHES BLUE LIGHT AND THEN AMBER LIGHT CONSISTENTLY UNTIL THE CHARGER IS DISCONECTED. I SUSPECT THE THE BATTERY,BUT I HAVEN'T USED THE LAPTOP FOR OVER 6MONTHS I BOUGHT IT
Posted on Aug 03, 2008
    Scholar:
  • 101 Answers
The DC power jack on the laptop may be worn out and needs to be replaced. Does it begin charging if you wiggle the power jack a bit?
Posted on Jul 20, 2008
My dell vostro 1014 laptop computer display driver stops working often and recovers automatically within few seconds, how to get it clear?
Try to download the latest driver and check the power saving options how long it takes the screen to turn off when the computer is not in use.
Nov 27, 2012 | Dell Vostro 1014 Laptop Computer
Using Dell laptop Vostro 1500, but battery cannot communicate with the system
There might be a possibility that the battery is not making good contact with the laptop's charging circuitry. To eliminate this possibility as a root cause of the battery not charging, turn off and unplug the laptop, take the battery off the laptop, and using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self. When done, put the battery back into the laptop, plug it, and turn it on.
Oct 24, 2010 | Dell Inspiron 6400 Notebook
My 1 year-old laptop Dell Vostro 1320 PC Notebook is charging but the batery is not lasting more than 33 minutes. even if its in the economy mode. it was good until one day i did some windows updates......
you update the firmware of the motherboard to correct this battery issue. Since it's more than a year it will be covered by the DELL hardware warranty if the problem is with the battery, but just to make sure that your existing warranty will not be voided call their helpline
Oct 23, 2010 | Dell Computers & Internet
Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Jul 21, 2010 | Dell Vostro 1500 Notebook
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Dvp4_disp blue screen for dell vostro 1500 when we open a specific programme
Hi
The problem seems to be related to display drivers, try reinstalling the display drivers for your dell laptop, you can get the drivers from dell support on this page http://support.dell.com/support/downloads/index.aspx
Let me know if you need further assistance.
Thanks,
Ekse
Aug 14, 2009 | Dell Vostro 1500 Notebook
My dell Vistro 1500 works on battries, but not on powder. Charger is tested and is ok
Seems that the battery charging circuitry in your laptop is defective.
The laptop needs to be serviced by a qualified technician.
Jul 19, 2009 | Dell Vostro 1500 Notebook
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
Power problem with dell latitude.
This is a failed power management system on the motherboard. The power management system regulates the power input, usage, allows the machine to switch from AC t battery, and controls the charging. When this fails it can cause problems ranging from battery not charging, power on battery only, power on AC or battery but not both, no power at all, and more. You will most likely have to replace the motherboard, however, there are a few places that do circuitry and component repairs on motherboards. Google motherboard repair facilities, get an estimate, and compare the price to a new board.
Jul 29, 2008 | Dell Latitude D600 Notebook
DELL LAPTOP PP19L - INPUT POWER FROM ADOPTER SHORT CIRCUITED - TO BE FOUND OUT
sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
http://support.dell.com/support/edocs/systems/ins630/en/sm/index.htm
Dec 02, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
362 people viewed this question
David Payne
David Payne
