Everything happens in proper sequence, on a call for cooling; Cendenser Fan runs, I believe the compressor is working!, Indoor cirrculating Bower delivers air (Not so Cool) to the supply vents. I have noticed that the air temperature above the Condenser Fan seems to be cooler than the ambient temperature.
  • dickschaub Jul 20, 2008
    That's correct, it's not cooling. I don't know if there is a low R-22 problem. I cleaned the condenser coil because I suspected that. (Didn't help!)
  • burzerko
    burzerko May 11, 2010
    Let me ask you what is your question is it not cooling correctly? Please comment me back and I will try to help you.
    Champion:
  • 254 Answers
This appears that you probably have a serious leak in the system. You will need to find this leak repair it. Then recharge the system.
Hope this helps You
please rate me
Posted on Jul 24, 2008
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
Unit has power bur will not turn on
You need to be specific to get help. Just what is happening? What is not turning on? The compressor? The fan(s).
Is thermostat properly set?
Jun 19, 2016 | Heating & Cooling
Air conditioner runs but does not cool
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Jun 01, 2011 | Friedrich KStar KQ06J10 Air Conditioner
Haier air conditioner will not kick on to air conditioner mode, only the fan runs, but does not cool like air conditioner should cool, just blows as a fan.
May 29, 2011 | Haier HWR08XC7 Air Conditioner
My Haier wondow air conditioner seems to be blowing cold air but it is not cooling the bedroom. It worked great a few nights ago and made the room really cold but now its not cooling.
May 28, 2011 | Haier Air Conditioner
Air conditioner will not turn on by remote green light keeps flasing and fan on outside box not working
Dec 15, 2010 | Carrier 36KCARMS Air Conditioner
How can you determine if a cooling air-conditioner humidity/temperature sensor is not working
Dec 10, 2010 | Maytag NMPEB08F2A Air Conditioner
Air conditioner bower dose not work
Nov 26, 2010 | 2003 Chevrolet Impala
Fan from my air conditioner start work noisy looks like same thing touch
Sep 13, 2010 | GE AGL10 Air Conditioner
Hi everybody i want some help , iam a technision in air conditions ,i was fix a central ac carrier and i found that everything works good the compressor and the high pressure fan and indoor fan ,but the...
if the compressor is running - the suction pressure should be 65-75 psi - if it is very low - not enough freon - if it is very high - the compressor valves could be damaged - both will cause this
Sep 19, 2009 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
