Question about GE GBS22HCR Bottom Freezer Refrigerator
Ice Maker doesn't work, condenser fan was not running
I shipped my fridge over to the Philippines from Virginia. Made it here 5 months later. Don't know how many times it was shifted around or abused. Got it in the house, plugged it into step-down transformer 220 to 110. It powered up, hooked up the ice maker supply to find that it didn't work. It made ice a couple times then quit. Freezer wasn't getting cold. The condenser fan wasn't running, so Mr. Filipino Sparky replaced the fan with an 110 volt fan which runs when the compressor is on. Now the freezer is cold. I tested the resistance on the removed DC fan and found it to be red to white lead is 1731 ohms and the yellow to white is 2945 ohms. I think the motor is OK? I need to check the control board, but need help? Does the control board also control the electronic ice maker and is there an electrical interface between the condenser fan and the ice maker. BTW, there is no green power light on the ice maker with the switch on. In other words will the ice maker work with my jack legged 110 volt condenser fan? Thanks in advance, Model number is GBS22HCRBWW, Serial number VG046480
Dave Cecil, Ground Zero for Typhoon Frank 6/21/08....Philippines
  • 1 more comment
  • Dave Cecil Jul 20, 2008
    The Freezer is working and the temps are 5 degrees below, I have been making ice in bags since the ice maker quit. I do not hear the timer motor running on the ice maker. I have on twice got ice out of the thing. But it hasn't produced squat since I disconnected and reconnected the water in an effort to see if my filter was a problem or not.
    Thanks, Dave
    Thanks for the info...still think I need a control board...I just want to make sure it is not the ice maker itself or the control board?
    Good info, will do it soonest, it is 8 PM here on Sunday...Thanks great info! I will be back to you with the results. Dave
    Genius:
  • 1,665 Answers
When your ice maker produces small or hollow cubes, it's a sign the unit isn't getting enough water. The cause could be a faulty thermostat or a bad water-inlet valve--problems you may want a professional to fix.
Or if you're lucky, you may just have a clog in the water-supply system.
See "HOW ICE MAKERS WORK " at link below
http://www.repairclinic.com/0088_1_3.asp#Level1_1
Posted on Jul 20, 2008
    Scholar:
  • 68 Answers
Hi Cecil
Im Dave
Hopefully I can help. If your fan runs then all freezer is getting cold than the fan is not your problem.
MODULAR CONTROLS
An icemaker's motor and switches may be in a module that must be replaced as a unit if any one part is bad. Holes in the module let you test the parts. CAUTION: Unplug the refrigerator before testing the icemaker motor or heater. Don't touch the jumper wire when testing the thermostat.
To use the test holes in the module, take off the icemaker cover and insert VOM(volt-ohm meter) probes in the holes. The components to test are usually listed inside the cover. When testing, shutoff arm should be down, and ejector blades should be in normal resting(2 o'clock) position.
To test module motor with VOM on RX1, insert probes into test holes L(line voltage) and M(motor). Look for a reading indicating significant continuity. Test heater in holes L and H(moldheater); look for a reading near 72 ohms. To replace module, take out screws and pull off. Replace entire module. If heater tests faulty, unmount icemaker, unscrew housing from ice mold-heater unit, and replace mold-heater unit.
Test thermostat with freezer cold. Unplug refrigerator. Insert bare ends of an insulated wire in holes T(thermostat) and H. WITHOUT TOUCHING WIRE, plug in refrigerator. If motor runs, replace thermostat. To replace thermostat, unplug refrigerator and unmount module and housing. Slip thermostat out of housing. Replace thermostat, using special metallic putty where it touches mold.
SEPARATE CONTROLS
In a non-modular icemaker, the motor, switches, and thermostat can all be tested and replaced separately. To reach them, UNPLUG THE REFRIGERATOR. Then take off the front cover of the icemaker and the mounting plate under it. There are usually three switches: The on-off switch is activated by the shutoff arm. The holding switch keeps power flowing to the ejector blades during the ice release phase. The water inlet valve switch controls the flow of water from the water inlet valve. When replacing the thermostat, use the recommended heat-transferring putty between it and the ice mold. To test on-off or holding switch, unmount it and take off leads. With VOM on RX1, probe COM(usually separate from and on the side of the switch) terminal and other two terminals in turm. Look for zero reading on one terminal, infinity on the other. Push button on switch in and retest. Look for reverse readings.
To test thermostat, unmount it, disconnect its leads, and let it warm to room temperature. With VOM on RX1, probe both leads. Look for infinity reading. Place thermostat in a working freezer, and test again. Look for a zero reading.
To test water inlet valve switch, unmount it and take off leads. With VOM on RX1, probe both terminals. Look for zero reading with button out, infinity when you push button in.
To test motor, trace and disconnect motor leads. With VOM on RX10, probe both leads. Look for a reading indicating significant continuity. Replace if infinity or zero.
  • 4,889 Answers
It could be the the control board or a broken wire in the door.
But if you hear the timer motor running then you are getting power to the ice maker.
Have you check the temperature in the freezer?
The freezer must be 5 degrees or below for the ice maker to work.
Here is a link on how to test the ice maker.
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
We have a four month old Frigidaire Gallery FGHB2844L fridge. We love it other than the fact the ice maker quits working to frequently. Right now it is not making ice. There is some frost build up on...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Frigidaire FGHB2844L
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working and fridge is hot on outside
This could be 2 separate problems or a control board issue. First I would check that the condenser fan is running, coils are cleaned. Here is a link to check the condenser fan http://appliancehelponline.com/referhotonsides.html If the fan checks out good more likely a control board failure.
Jun 07, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
Jun 02, 2010 | Viking 42 in Built In Professional...
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Mini fridge-ice maker stopped cooling. Cleaned coils underneath-still not cooling
If it is running but not cooling, I"ll clean the condenser first then make sure the condenser fan motor is running, if the condenser fan motor is not running, re place it with new one, or if compressor and condenser fan motor are running then it will be sealed system problem, if it is not cover by Warr. it is not worth to fix it.
Nov 18, 2009 | U-Line Refrigerator Ice Maker
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE GBS22HCR Bottom Freezer Refrigerator Logo
209 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
