Question about Hotpoint Refrigerators
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
    Scholar:
  • 50 Answers
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Posted on Jul 20, 2008
Hot point Manufactured by GE MD# HSS25GFPE WW Not Cooling Fridge or Freezer.
Is compressor (black canister)running? It should be very warm if it is. If not, motherboard is most likely bad.
Oct 20, 2017 | Hotpoint HSS25GFP Side by Side...
HOTPOINT Refrigerator HSS25GFPE WW - Freezer has some frost and cools but do not freeze. The refrigerator is not cooling at all. Can not ifind the mannual or ifnormation of this particular model in any...
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Hotpoint Refrigerators
Just moved, don't know how to hook up water supply to HOTPOINT MODEL # hss25GFPE WW
Find the water valve down by the compressor and connect your water supply, check for leaksthemobilian_52.gif
Apr 11, 2011 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
My hotpoint fridge dispenses ice, but not water. The filter has been changed. Model #HSS25GFPE WW
Set up a shop light, one of those Halogen type lights. And have it shining right on it at the highest setting. The water in the line has frozen. After about 30 minutes to an hour it should start working again. You could also use a blow dryer but I'd rather not stand in front of the fridge that long. Remember if you got kids in the house to warn them not to touch the light!
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Hotpoint hss25Gfpd ww, wtf?
if water comes from bottle at bottom of fridge, prob may be that the bottle is frozen
Feb 28, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
217 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
