Question about RCA HD56W58 56" TV
Won't power on. Burning smell, High pitch arcing sound,
I found a component under the screen, easy to get to, that has the part number 1590395a that is burnt. It also had VDE Reg N. 7403 506, 70211506334488, TCE 70234 , 1/feb/2005 on it, 1517923, CAV2, Sub 3. It resembles a distributor off of on old car, tan in color with a waxy looking substance on the botttom. I haven't been able to find the part on the web yet, Just found it today. Any ideas as to what it is and how to get it. I am a CATV/Phone/IT headend engineer and I deal with electronics all the time, but have never worked on a TV. Lack of experience has never stopped me b4 so why stop now?
  • WinkMeister Sep 10, 2008
    I am having the EXACT same problem. I turn on the set, and get a high pitched screech/squeal from the front speaker, then no noise and the power light satys on for a few seconds then flashes a few times then goes back to solid for about 30 secoinds before shutting itself off.
  • Abbie Workman Nov 07, 2012
    I wish SOMEBODY would answer this question. I had the exact same thing happen this week. I Love my TV and really would rather not have to replace it. Any ideas???
I have a HD56W58 and it had the same problem. One day the picture went blank and then it made a loud popping sound and smelled like something burning. Now it will not turn on. Has this happened to anyone else? I
Posted on Oct 05, 2008
2004 Dodge ram made high pitched sound and smelled burning under hood air stopped working
I'm going to fires blower motor bearing failed causing excessive power draw from motor
May 19, 2013 | Cars & Trucks
Dodge caravan 2001 blowing burning power steering fluid.
I can answer some of your questions without being there in person.
The smell inside the van is from fresh air entering the venting system. Not sure why you don't get it from all vents. The fresh air intake is in front of the windshield and will pick up any smells from the engine compartment.
Loosing the serpentine belt would not necessarily cause you to loose ps fluid, but having a leak could drain the pump and damage the bearings in the pump, causing the pump pulley to drag on the belt.
The ps pump could be in the final stage of failing.
And the shaft seal in the pump could be leaking fluid onto the engine and exhaust.
Feb 23, 2013 | Dodge Grand Caravan Cars & Trucks
Screen went black sounds of crackling and smell of burning wires
Hello
There is somethin wrong with either its EHT section or power supply section. Your description gives me very little to say a strong opinion. In both cases, it is very dangerous to handle the components at these sections. If you haven't got enough experience in handling high voltage electronic sections, never attempt to do anything with this TV. Normally EHT arcing is more common to this type RCA sets. In my opinion, get it repaired by any experienced service technician. OK.
May 24, 2011 | RCA D52W19 52" Rear Projection Television
MPV 2001 burning smell, high whine?
Sound like the alternator bearings are seized or about to seize. The noise could be the bearings or the belt and the smell may be either of them also.
Jun 01, 2009 | 2003 Mazda MPV
Burnt part. no pic. no sound
You can get them online at http://www.partstore.com . they run about 55.00 each part
Nov 23, 2008 | RCA HD56W58 56" TV
High pitched noise comin from sub
if sound also goes away when throttle is released and sound returns when throttle is pressed down, then you have engine noise from car engine electronics. In older cars, this was quite noticeable when the cars had distributor caps. The electrical noise caused by arcing required for the spark plugs could be your issue. It is resolved with a noise filter which gets wired inline leading to your in-dash deck and power amp (if you have one). The filter can be found many places including Radio Shack and Crutchfield.com. First find your total wattage draw for each component of the sound system (deck and amplifier), then divide by 12 to get current draw through filter. Purchase that size filter or larger.
Feb 12, 2008 | JBL GT1041 Car Subwoofer
High pitched rattling not associated with TV audio
Quite possibly the HVT arcing, which will eventually fail.
The problem with them arcing is they can be doing damage to other components.
Best to have it checked by an experienced tech.
Jan 06, 2008 | Toshiba 32AF42 32" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RCA HD56W58 56" TV Logo
236 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
