FixYa.com
Tags:
RCA RCR311B Remote Control
Help (by 2 users)
posted by soon2bstarra on Jul 20, 2008
i need the code for my remote, so can put my tv on chan.03
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by khorisantone, posted on Jul 24, 2008
I have a RCA311B remote control for a magnavox television and all the codes listed for me are invalid and dont work. I need the correct code so that i can change channels. Are there any other available codes for my magnavox television?
Best Solution
posted on Jul 28, 2008
Thanks for Trying (70)
locote314
Rank:Guide Guide
Rating: 92%, 22 votes
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Remote Controls problems?
My Rca Tv shuts off and on
I've had my rca 37" tv for... Answer This...
Need help with programming
Lost manual, have orion tv Answer This...
remote will not change to input...
My remote is like the 311B... Answer This...
programmableremote
program my remote to my tv Answer This...
remote exits Auto Code Search
Every time I pushed a button... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
