Question about ASUS P4S533-X Motherboard
Bios is always re-starting
Bios is always link to the set up menu what is the specific solution?
  • 2,427 Answers
Is called ottimised defaults or load defaults.. or simply enter then save and exit or load the defaults then save and exit
if after you load the defaults and it pops up again then the mainboard battery may need replacing
Posted on Jul 20, 2008
Restore a HP dv4000 laptop to factory
If the restore partition is still there, press either F8 of F11 just before boot up and follow restore/rescue links from menu.
Sep 19, 2014 | HP Pavilion dv4000 Notebook
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Hardlocks and or Resets!
It sounds like this bios may not be for your specific revision of motherboard. If you were upgrading the bios to solve a specific issue, check to make sure it's compatible with your board.
If you were upgrading the bios just because it's newer, this is always the wrong thing to do to a working system. Re-flash the board with it's original bios.
May 14, 2012 | Intel DP43TF Motherboard
My desktop has been starting automatically at midnight, what is causing it?
Is it always at the same time? There are a few ways to get a desktop to do this, both use specific times as a reference. There is a configuration setting in many computers in the BIOS, that turns on the computer at a specific time. Also if for some reason your are losing power every night, the BIOS has a setting to turn on after power is restored.
Mar 21, 2011 | ASUS Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
How disable my bios memory dump and bluescreen thans you
These controls are located in a part of the system called "BIOS Settings", "BIOS Menu", "CMOS settings", "CMOS setup" or some similar variation. This should be covered in your user manual.
You usually enter "BIOS Settings" menu by pressing a specific key or keys during the beginning of the boot-up process. The specific key(s) to press are usually mentioned in a corner of the display as the system boots. They should also be in the manual. It is sometimes the "F2" key, or "Del", or a combination like "Ctrl+S" keys.
Once you've entered the menu, you'll see it provides many parameter settings organized in "pages". Basically, walk through the on-screen prompts until you see the settings having to do with cacheing and shadowing.
Every system and even current BIOS version has a different way to present these data, so we generally can't give you a specific keystroke-by-keystroke set of instructions. Again, your user manual should detail this information.
If you don't have a current user-manual, you should be able to go to the motherboard or system manufacturer's website to download a copy. It will usually be in .pdf format which will (in order to be able to read it) require a free .pdf reading application like Adobe Reader or Foxit.
Mar 31, 2010 | Computers & Internet
F11 does not work for restoring my PC
-you might try to hit F8 and get to safe mode
-From there, you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Mar 25, 2009 | Dell Dimension 3000 PC Desktop
My toshiba satellite a50, i want to change boot order to cd drive
You need to go into the bios or utility set up. At start up there will be a Toshiba screen, on this screen at the bottom, it will read something like, esc to enter bios, or F1 to enter bios, F10 to enter boot menu, at this point you will need to press which ever it says to go into bios. Bios can also be refereed to as utilities or utility set up. Now, if you change the boot order in the bios, it will always check the CD drive before the hard drive. If you only want or need to boot from the CD drive this one time, then you will need to go into the boot menu at start up. When you get to the boot menu, it will give you a list, then you choose CD drive. If you go the boot menu route, be sure the CD is in the drive when you select CD drive, otherwise it will see there is no CD and skip straight to the hard drive. Keep in mind that on some machines it blows right past the Toshiba screen, so you may have to try a couple of times or just be quick to make your selection as to bios or boot menu.
Jul 03, 2008 | Toshiba Sattelite A105-S2071 Notebook
Usb 2
Hi truckereric, The short answer no.
USB 2.0 is acheaved by two things.
1. You need to enter your system boards Bios. Find the USB settings. If USB 2.0 is listed here than your board will support it.
2. USB 2.0 is installed through windows updates.
3. If your board can't handle USB 2.0 maybe there is a Bios update. No, I checked your bios & there is no bios update to bring you up to USB 2.0.
AOpen's driver / software & bios support found at the link posted here. http://download.aopen.com.tw/Default.aspx
You'll need to fill in the three dropdown menues.
Motherboard
MX4BS
& Order by: LastUpdated
There are five pages of updates. If you change the Category dropdown menue to Bios. AOpen will show you the bios updates.
At least you have AOpends update link.
You can always add a PCI card that supports USB 2.0
http://www.buyextras.com/synecchusb20.html?gclid=CP_cvvGF_pECFQuAHgod0mYK4w
Best regards.
Mar 08, 2008 | Computers & Internet
MEMORY PRESARIO 5441 SER#3H9ACT9EX1L1
Hello, If I understand your question correctly. You want to upgrade your current memory? The link below shows me what your PC desktop came with, (Installed Items). Specifications.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&docname=c00031041&dlc=en&product=93344&printable=yes&
You want to enter your bios & see just what ammount of memory is installed in your 5441 PC. This is how to get into your Bios. Not every PC has the same F key to enter the bios. Turn your monitor. Than start your PC. Watch your screen closly. It will display, Enter setup Press (F ? ) That is how you get into your bios menue. If your Pc did not display this or went by too fast to see than, Re-start the Pc & press the F2 key every two seconds & see if the Pc enters the bios. It could also be the F10 key or F12 Key or the F1 key. Re-try each till you enter your bios. I'll list another link that sell's memory for your 5441. Use the Specifications link above as a guide when picking the ammount of memory you may want.
http://www.google.com/products?hl=en&q=PRESARIO+5441+memory&um=1&ie=UTF-8
Now you have what you asked for & a wee bit more.
Have a nice day. Have more questions, just post back.
please vote...
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
ASUS P4S533-X Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
