Simpson aquapulse 714 wash machine stopped during work and can not drain water. Turned off again and went to advance function, but show FC sign only. pls help!
Stops while in spin cycle pu code comes up
Posted on Oct 06, 2010
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Nov 12, 2016 | Simpson Washing Machines
The water is not draining out of the washing machine what could be wrong
not much info out there on this one
water pump solenoid or water pump
faulty control board timer
to empty machine run drain hose out the door
or towels and buckets
Sep 17, 2016 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Simpson washing machine will not fill
faulty control board or timer
Nov 19, 2017 | Washing Machines
Simpson aquapulse 713
Remove the clothes and check for free movement of the drum, if there is friction then check the motor and belt assembly, check the free movement of the bearings. Also make sure that the inlet water level is good and the water level set is correct for the clothes quantity. If not the clothes will be dry on top and might cause such an issue
Oct 03, 2013 | Washing Machines
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
May 21, 2010 | Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Washing Machines Logo
307 people viewed this question
Top Washing Machines Experts
