Sharp UX P200 Plain Paper Thermal transfer Fax Logo
Posted on Jan 31, 2011
What's the procedure in sending documents.. - Sharp UX P200 Plain Paper Thermal transfer Fax
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
474
Points
11
I punch in the phone # first, then hit resolution(fine, extra fine, etc). place original facing away from me in the carriage, then hit send fax.
KONICA MINOLTA 258 ERROR CODE CFA14
We had one here but fixed by doing firmware.
Check the marketing area is correct for your region
<Symptom>
"Please turn main switch off and on."(FA14) may be displayed if the following procedure is operated.
<Reproduction Procedure >
If "Other3" is selected in marketing Area setting, "Please turn main switch off and on."(FA14) may be displayed when performing Scan sending the following orientation mixed document.
- 8K or 16K and other document size.
How do i convert my adcom gfa 6000 from 115 ac to 220 ac? thanks
It's a small job because the GFA-6000 transformer has dual 110v primary windings so you just reconfigure them to run in parallel thus doubling the input voltage to 220v. It takes less than 10 minutes, small allen wrench to remove the top and a screwdriver to redo the wires. Basically, you need to remove the top cover and change the terminal position of a few wires. Just email adcom and they will send you a document that tells you the exact procedure. If you can't get a response from them, post back here and I'll try to dig my document out from my mountain of papers and detail the procedure. However, this is something that any competent electrician / electronician should be able to do for you at a very small fee without even requiring documentation.
Kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
I have hp laserjet 3050 guide me how to connent fax and how to send fax
Sending and receiving faxes by using a computer
This section contains basic instructions for sending faxes by using the software that came with the allin-one. All other software-related topics are covered in the software Help, which can be opened from the software-program Help menu.
NOTE The HP fax software and HP ToolboxFX are not supported for Windows 98 or Windows Me. The HP ToolboxFX software is not supported for Macintosh.
NOTE Receiving faxes by using a computer is not supported for Macintosh.
You can fax electronic documents from your computer if you meet the following requirements:
? The all-in-one is connected directly to your computer or connected to your computer over a TCP/
IP network.
? The all-in-one software is installed on your computer.
? You are using Microsoft Windows 2000 or XP or Mac OS X V10.3 or Mac OS X V10.4.
To send a fax from the software (Windows 2000 or XP)
The procedure to send a fax varies according to your specifications. The most typical steps follow.
1. Click Start, click Programs (or All Programs in Windows XP), and then click Hewlett-Packard.
2. Click HP LaserJet all-in-one, and then click Send fax. The fax software appears.
3. Enter the fax number of one or more recipients.
4. Load the document in the automatic document feeder (ADF) input tray.
5. Include a cover page. (This step is optional.)
6. Click Send Now.
NOTE You can also send a fax from HP ToolboxFX by navigating to the Fax Tasks section
and clicking the Fax Send button.
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
What is the procedure to send a fax
To send a fax using the printer operator panel, load the original document on the scanner bed or in the document feeder > press the Fax mode > enter the fax number > press Start Color/Black. For more information on how to use the Fax function on your Lexmark X6500 Series printer, refer to the Lexmark X6500 Series User's Guide.
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Sending a fax
If you are making a local call, you do not need to enter 1.
Load the document to be faxed into the machine, press the 'hook' button or equivalent, dial the fax number and it should automatically send
2answers
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
