Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Removingand replacing screens on Akai-PT5499HD
How do you remove screens to clean and which screen is the lenticular and frensel,which is the front screen.Can a small crack in front screen be repaired or will it have to be replaced! Thanks alot!!
    Scholar:
  • 167 Answers
HELLO. WELL YOU WILL NEED TO TAKE OFF THESPEAKERS GRILL'S ON THE FRONT OF THE SET .UNDER THEM YOU WILL FIND SCREW'S THAT HOLD IT ON . THE FRONT OF THE SCREEN IS THE FRENSEL & THE BACK SID OF IT IS THE LENTICULAR. LENZ. WHEN U CLEAN THEM USE ONLY SOAP AND WATER AND A VERRY SOFT CLOTH. NOTHING ELSE. OK AND FOR THE CRACK IN THE FRONT . YOU CAN USE ELMER'S GLUE . THE WHITE GLUE. IT DRY'S CLEAR. BUT MOST PEOPLE FIND A NEW ONE . ON LINE CHEP. WELL HOPE THIS HELP'S YOU.
"GOOD LUCK"
Posted on Jul 27, 2008
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
After a move to a new home the screen broke. need
Howdy,
Yes, you can still get them from the Factory. I just checked and Mit's has all items in stock.
The SCREEN- LENTICULAR IS; 491P103030: $171.10. The LENS-FRENSEL IS; 491P104030: $212.80. The Diamond Shield IS; 760D639020: $77.90.
Dec 29, 2009 | Mitsubishi WS-55511 55" Rear Projection...
SCRATCH ON SCREEN
front screen is a protector but also helps with the image quality. new screen runs about 190 dollars
Jun 02, 2009 | Akai PT61DL34 Television
Can front screen be replaced
all projection screen can be replaced but they cost quite abit of money
Jan 18, 2009 | Akai PTH5498 54" Rear Projection...
AKAI PT5499HD
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
thanks
Sep 16, 2008 | Akai PT5492S 54" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Hitachi 50vs69a
Spanking comes to mind... :) Just kidding..
You can access the inside area od the screen and with some windex and paper towel clean the reverse. There are actually two screens there sandwiched together, a lenticular and frensel screen. If you remove the front panel you should be able to remove the screens from the frame and clean between them also... If any of this makes you nervous calla qualified shop and they can do this in minutes on a house-call..
Have a great day!
Bill
Nov 21, 2007 | Televison & Video
LENTICULAR SCREEN???
From an AKAI service center. Try Google or the phone book.
Sep 22, 2007 | Akai PT5250A Television
SCREEN FOR PT5499HD
Check this out USA AKAI CUSTOMER CARE 1-800-726-4405 Hours of operation (Eastern Time): 8:30 am ~ 9:00 pm (Monday through Friday) 9:00 am ~ 5:00 pm (Saturday) CANADA AKAI CUSTOMER CARE 1-800-293-5408 Hours of operation (Pacific Standard Time): 6:00 am ~ 6:00 pm (Monday through Friday Good Luck
Aug 15, 2007 | Akai PTH5498 54" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
161 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
