If you have another device that plugs into the back of the tv does it do the same thing?
Same Problem
Apr 13, 2009
-   i have the same problem with no sound from this dvd player. the cables an settings are correct. i also tried the turning on and off of the night settings with no results. need your help -   benoo
Mar 12, 2009
-   I have the same problem. I have to turn up the volume on my tv to hear the audio, but it's still not clear. When I placed my other dvd player, thinking it might be the cables, which it's not, it works fine - sound is great. Your solution doesn't help. I reset the tv and the phillips dvd player to it's factory settings. Any solutions?
-   Guest
Turn off the night mode on the Philips:
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
I tried the nigh mode ON/OFF and all audio setup but with no avail. There was no problem until...
(More)
I tried the nigh mode ON/OFF and all audio setup but with no avail. There was no problem until recently but now no matter what there is very low sound even after having the volum maxed out
CDs plays but after 5-7 minutes running it stops automatically and screen goes blank and even the...
(More)
CDs plays but after 5-7 minutes running it stops automatically and screen goes blank and even the power light on DVD goes off. I have to switch off the power from the plug and start again. CD starts afresh in this process. What may be the problem?
