Pull cover off front of air conditioner and radiator freezing over
  • 143 Answers
It either has insufficient air flow through the cold coil or some of the refrigerant has leaked out.
Posted on Jul 22, 2008
My central air is leaking onto the floor
Take a shop vac and suck out the white condensate drain line you are probably stopped up, You don't need to find the raidiator, you are either stopped up or it low on Freon and freezing up are the lines getting ice on them? If not you are stopped up in the condensate
Aug 02, 2014 | Coleman Heating & Cooling
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
I clean the filter almost everyday because it freezes and no cold air comes out.frigidaire faa068p7a is this normal?
The evaporator maybe dirty. You can flush it water. There is also a spray available at A/C supply for cleaning evaporators. Anyway the evaporator is the radiator looking thing at the front behind the air filter. Air passes through it to provide cooling air. It gets very cold and if the air cannot pass through it will freeze.
Jul 22, 2010 | Frigidaire FAA068P7A Air Conditioner
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
How do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Dec 12, 2009 | Hunter 30124 Air Conditioner
Dometic duo-therm air conditioner freezing up
Make sure that you are not running the unit on low fan speed. In the warmer months of the year, this will often cause the unit to freeze up due to the lack of air flow through the evaporator. If you are running on high and it is still freezing, then you possibly have a freon leak in the system. The brisk airs are notorious for the capillary tubes in the upper unit rubbing together and developing a small leak. The problem is usually where the two small tubes enter the evaporator housing. Remove the cover and pull the two small lines apart, damage should be apparent if there is any. If not, you may have developed a leak elsewhere and need to have someone check out the system.
Hope this helps,
Jeff
Jun 23, 2009 | Dometic 57915531 Air Conditioner
How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Feb 21, 2009 | Fujitsu 18R1 Air Conditioner
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Foam filter fabric
Yes you can buy it in hardware, just cut it to fit in the frame.
Feb 26, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Dec 20, 2007 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
