MY COMPUTER DOESN'T EVEN START, BUT THE LIGHT THAT TURNS ON WHEN THE COMPUTER IS ON IS ON...EVEN THOUGH IT IS OFF
  • 2,427 Answers
Hmm
try 1.) unplugging the sytem
2.) open the side panel
3.) remove the battery on the main board
4.) press the power button for 5 seconds then release
5.) put the battery back in
6.) put the side panel back on
7.) plug in the system
8.) turn it on
9.) when the screen loads enter the setup menu
10.) load the default settings
11.) your done
Posted on Jul 20, 2008
Why doesn,t my computer connect with my modem & doesnt even connect though a wired conection ???wifi says no nework in range??? when the modemis right beside it???
If you have a laptop check all sides to see if there is a switch to turn it on, if not look at the keyboard and see if there is a wireless icon on any of the keys .If found Press the FN key and the wireless key to turn on.
Oct 03, 2014 | IBM ThinkPad Computers & Internet
My 1993 Vette is driving me crazy!! It seems to always start 1st thing in the morning. Then I can drive it all day sometimes without any problems (doesn`t happen very often anymore) and some times I will...
Electrical issues are the most difficult to fix. If you can't duplicate the problem in the shop, you're usually out of luck. It could be a weak relay for things like the fuel pump, a weak electrical connection somewhere, problems with the circuit board inside the engine computer, and so on. It would help if you could narrow down the area of interest like fuel or spark. Carry a can of starting fluid and a spark plug tester and be ready to check things when it quits running or won't start. And check the computer for trouble codes even if the check engine light doesn't come on.
Jan 21, 2014 | 1993 Chevrolet Corvette
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Feb 25, 2013 | HP Pavilion dv6704nr Notebook
My 1998 suburban turns over but wont start, and the battery light goes on and off.
Yes, even though the battery might have enough power to light the overhead bulb, it may not have enough power to turn the starter.
FGTech Galletto 2-Master EOBD2 V51 BDM-TriCore-OBD
Dec 17, 2012 | 1998 Chevrolet Suburban
TV will not come on even though the light turns blue
check for leak or bad capacitors in the power supply board, then if you can make a voltage checking just to ensure if output voltage in the power supply board are present. the 5v standby 5v switch 12v and 24vdc at the power supply doesn't drop.
Sep 03, 2012 | Televison & Video
Pc wont start up
Even though the fans are running it doesn't mean the power supply is ok. Buy a PSU tester or bring it to a computer shop to have the power supply tested.
May 19, 2012 | ASUS AI Lifestyle P5N32-E SLI...
Microwave oven doesn't work but light turns on
It sounds as though you have a defective electronic control pad.
May 03, 2012 | Frigidaire Microwave Ovens
Truck won't start
hours of surfing and I found out it's one of my batteries or posts. Cleaned the posts and it started. Even though no battery light came on, that's what it was. Thanks for e-mailing me back.
Jul 04, 2008 | 2001 Dodge Ram 2500 Truck
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
