LG DD Washing Machine
We've put up with the problem for the past 2 months and it's been a pain in the proverbial. Now have time to have a look at it and I'm wondering applking, if the stator is bad, why should it occasionally do a complete load without any hiccups whatsoever? Is it not more likely to be a loose connection somewhere? I'm no expert and your advice is much appreciated. I am going to reseat the connectors and try again b4 buying new parts and will let you know the result.
Warm regards and many thanks. Bas
  • Bas Dolkens
    Bas Dolkens Jul 20, 2008
    Well, I tried that. Didn't do anything inside the stator / rotor thingamijig as it looks like a job for an expert.
    Result is no good, problem remains unchanged so will have to call for professional help. I think it was worth a try, would have been more confident if I had been able to find a workshop / service manual, and I thank you for your assistance. Warm regards, Bas.
  • Bas Dolkens
    Bas Dolkens Aug 25, 2008
    Hiya applking. We've replaced the big PCB at the bottom/back of the machine and it has been working perfectly again for the past 3 weeks. Interestingly, when the tech replaced it one of the connectors was loose which also threw up the LE error code (but lots of other weird things happened as well) so the LE can show up for things other than a stator problem. I waited a while to get back to you to make sure that the problem was truly fixed because the PCB could have been damaged by another faulty part (even a stator maybe?). Thanks for your help though, it was really appreciated. Warm regards, Bas
  • 135 Answers
The stator is always the problem if you are getting the LE error code. It will work sometimes because the stator is "weak". So depending on the size of load, ect. sometimes it may get through the whole cycle.
Posted on Jul 22, 2008
  • Michael Thibodeau Jul 28, 2008
    Sorry, I would have walked you through changing the stator....not that bad of a job.....
  • Michael Thibodeau Aug 28, 2008
    Glad you got it resolved. Very rare for the harness to be loose at the board, but In 14 years I still see new problems daily. Let me know if any further problems.
Sometimes the clothes come out of the washer dirtier than when I've put them in! Brown streaks that sort of come of with my finger - sort of like wet dryer lint or sludge. Rewashing takes them away,...
Your washer has too much build up of sludge from excessive use of detergent and fabric softener. You will need to purchase a package of washer machine cleaner from the local hardware store and run the washer on either "clean tub" setting or "sanitary" setting without any clothes in it. Use the cleaner at least once a week for one month and then once a month for maintenance.
Use only 2 tablespoons of detergent per wash.
Good luck
Jun 17, 2011 | LG WM2301HW Front Load Washer
Setting up date and time
Please check the date display format
In your mobile it might have set to this format
MM DD YYYY
So as the first column is in months as you enter 24 it doesnt accept and shows 02 ,This is because you have only 12 months in a year.
So please type month date and year.
If you want you can change the format to DD MM YYYY in date and time setting option.
Thanx
Thanx
Jul 24, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
Mold on gasket of LG WM2016CW
the biggest problem with front loaders is that the seal is so good you end up with a moisture issue all the time (which will cause mold). My suggestion to you is always leave the door open when not in use and also try not to leave clothes in the machine after a cycle is over. leaving the door open and a few good cleanings will solve your problem
Aug 22, 2009 | LG WM-2277HW Front Load Washer
My Nokia N-70-1 has the wrong date, I tried to correct it. But it won't go past the twelth of the month and its well past the twelth. I need to get the correct date please help!!!
it looks like you are trying to put the days in as months, there is a good chance that the date format is wrong, you can change from dd/mm/yyyy but it looks like it is set to mm/dd/yyyy, go into settings/date and time/date format and change accordingly. good luck
Aug 21, 2009 | Lands Phones
Water stagnant
check ur inlet valve looks like u have to call service to fix this problem....
Mar 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Sep 19, 2006 | LG WM1812C Front Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
