Question about Whirlpool Duet GHW9150P Front Load Washer
HOW TO REPLACE A DUET FRONT TUB SEAL
My washer is leaking and I noticed their is a tear in my front tub seal. I want to replace it but do not know how.. the manual provided does not even give a part #. I am mechanically inclined and can do it without having to pay a service call (whilpool) but need to know how to replace it. Can anyone tell me how to replace this on my Duet GHW9150P
Any help would be appreciated.
  • 246 Answers
Once you have your replacement boot (or seal) (availible at local appliance parts stores or from the manufactures web site on line), You can follow these steps:
1 - Remove the front clamp. (a silver peice of wire with a spring at the botom) A small flat head screwdriver will let you pull/pry it off.
2 - You may have a green clamp on a black hose that comes from the dispenser to the top of the boot (seal) on some models that you will have to disconnect.
3 - The main water inlet (about the 9 o'clock position can just be pulled off (and worked back on durring re-instalation)
4 - Remove the second clamp on the back side of the boot (it's a flat piece of metal that has a screw on it at about the 3 oclock position. Turn it counter-clockwise to loosen. (clockwise for installing the new boot)
5 - Pull the old boot free.
6 - Reverse the procedure making sure to line the new boot up at the top. (there is a arrow that shows where to align the tub [white piece of plastic] and the boot). There is lip on the back of the boot that will seat all of the way around it.
7 - When putting the front clamp back on (the wire and spring combo) there is also a lip to seat around the front as well. When putting on the clamp, use a small flat head screwdriver inserted into one of the holes next to the spring. Then using a pair of needle nose pliers or another screw driver, work the way around the edge re-seating the clamp over the lip.
Tips:
To make it easier and give a bit more room for this, you can pull the machine forward, then tilt it back until the machine will balance resting against the rear wall. This will give you more room)
You can easily remove the lower front panel by removing the 1/4" screws along the bottom of the panel and lowering it down. Not only will this give you some beter angles, but it will also let you check quickly for leaks once you start the machine again.
Posted on Jul 20, 2008
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Just wondering can the rubber seal be changed on my Whirlpool duet front load washer? The seal around the tub of my machine has a small rip in it and now the water flows out when I am washing my clothes.
yes they can, the bellow seal is about $100 and take care when removing the outer tub spring and the front seal spring so you don't kink these or the new seal will leak around the edges
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have off and on leaks under washer does not matter what cycle it is in and does not happen every time any suggestions . we had a person come take a look he adjusted door but this did not fix.
Inspect the door bellow (seal) for any rips or tears. It may be worn or loose and require replacement. This is a fairly simple repair that anyone can do with a little guidance. The following link explains step-by-step how to install a door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Although the bellow may not have any physical tears, they can also become mishapened over time due to normal wear and not seal properly. You should have a good tight seal all the way around the door.
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Some additional items to look for that may cause leaks:
1. Check the dispenser tubes that pentrate the door bellow. Sometimes they get pushed behind the rubber causing the water to trickle behind the bellow and leak. You will notice this on fill and rinse.
2. Check the rear bellow clamp that holds the seal to the front facing of the wash tub. The clamp can come loose, causing it not to seal properly.
3. Check the drain pump and drain hose. If you notice any pooling of water in the cabinet it could be a loose drain hoses or a leaky pump.
4. Check the area under the wash tub. The tub consists of two halves bolted together with a seal in the middle. If the seal is leaking it may need to e replaced. NOTE: This is a labor intensive repair.
5. Check the right hand side of the wash tub for a small air dow hose. Sometimes this hose comes loose and starts leaking. This hose runs to the pressure switch and is what is used to sense the pressure differential in the wash tub. If this hose is leaking, you would have problems with the washer overflowing.
Nov 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front loader washer is leaking at the door and it don't seem to get my clothes clean what do i do
If you have any questions, please let me know. I hope this helps you.
Some additional items to look for that may cause leaks around the bellow:
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking underneath and pouring out of side
If this is a Whirpool Duet front loader, you will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link epxlains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking bellow for duet washer
Whirlpool sells a product called Silco-seal it is a high temperature adhesive for sealing tub hoses to tubs this can be purchased at an appliance store it sometimes works to seal a tear or, hole in a bellows
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
470 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
