Question about Whirlpool RF364 Electric Kitchen Range
BOTTOM COIL DOES NOT HEAT UP
When I go to bake something only my top coil in the oven goes on and it burns everything since it get to hot and E2 - F3 displays then it locks on its own.
My bottom element in my Whirpool range needs to be replaced. It is hidden. How do you replace it?
Posted on Jul 26, 2008
What would cause the broiler element to override the baking element? My oven has lost its mind. It doesn't matter what setting I use, The broil element takes over and burns everything. Please help.
Not 100% sure but my guess. Most electric ovens usually bake with both elements on. The bake element(bottom) is usually on at full power with 240 volts to it. The broil element(top) is usually on at 1/2 power 120 volts to help even out the temperature. My guess is your bottom element is not coming on at all either because it is burned out or something in the control system. So what is happening is the oven is trying to heat to the set temp with only the top element keeping it on much longer than it normally should be on and burning everything. Now if you set the oven for bake and the top is on red hot, you have a control system problem something like a bad selector switch or main control board if the oven has a electronic control.
Apr 10, 2015 | Ovens
Whirlpool mod# rf365pxmt top broiler comes on .
This is usually a oven too hot error code. It may be the oven sensor going bad. The control relay stuck. try shuting the power off and resetting it and see if it comes back.
Oct 06, 2014 | Kitchen Ranges
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
E2 f3 and locked on my oven, and the heat is coming from the coil on the top of the oven, why is this
e2-f3 meens your oven sensor is bad. if you look in the back wall of the oven you will see a probe a little smaller than a pensil held in by two screws. remove power then the screws and slowley pull the sensor into the oven far enough to unclip the wires. sometimes you have to remove the back to do this then replace the sensor.good luck!
Jan 18, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Bake burner (top coil) won't shut off - troubleshoot code shows F3 - E2 - Bake Range Over Temp.
This could be a welded-shut relay. Usually located on the oven control board (ERC/clock). If so, we can repair this for you if you can safely remove and send us the control board. What make/model do you have?
Regards,
Bruce
www.fixyourboard.com
Aug 31, 2009 | Ovens
Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Oct 02, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpool RF364 Electric Kitchen Range Logo
204 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
