Microsoft Xbox Console
Problem for Microsoft Xbox Console
07 red light on original XBOX
By Taz 21 on Jul 20, 2008
I turn it on and it has the start up but once it gets to the xbox logo it stalls for about 15 sec and then go's to saying it needs to be seviced and I have the #07 and I dont know much on fixing stuff and I need help
Same Problem
Apr 10, 2009
-   I turn it on and it has the start up but once it gets to the xbox logo it stalls for about 15 sec and then go's to saying it needs to be seviced and I have the #07 and I dont know much on fixing stuff and I need help-   Guest
Apr 04, 2009
-   My xbox gets to the xbox screen and then the green light starts to flash red and tells me to go to customer suppourt. But if leave it alone for about a month, it works again.-   pinkpurplegr
Best Solution
posted on Jul 26, 2008
Helpful)
sanjuro77
Rank: Wiz
Rating: 89%, 36 votes
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If that won't work try another harddisk. If there is still no go, try to set the jumpers on the rearside of the harddisk drive. Set it to master or cable select.
If that doesn't work, it probably means your hard drive is shot. There are ways to replace it, you can learn how to do it here:
http://forums.xbox-scene.com/index.php
or here:
http://llamma.com/xbox/Repairs/Reading_Xbox_Hdd_key.htm
It will involve opening your Xbox, building a small device out of about $5 in parts from Radio Shack, using that device to read your eeprom.bin file, and then finally using a program called XboxHDM to create a new hard drive (a WD Caviar works well).
But you can find a used Xbox for around $50, if all that seems like too much trouble.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 24, 2008
Somewhat Helpful)
sdlj
Rank: Apprentice
Rating: 71%, 3 votes
buy a new Xbox and there's your solution to it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox Console
Questions and Unsolved Problems for Microsoft Xbox Console
Do you recommend Microsoft Xbox Console?
Answer
Answer
my xbox 360 is coming up saying contact xbox customer support and at the switch its flashing red... (More)
Answer
I'm trying to use my original Xbox with xbmc to display HD with component cables. I bought two sets... (More)
Answer
Xbox controller will not work. Tried new ones still will not work.
Answer
i have internet connected to my xbox but i dont have a xbox live subscription dont i get a silver... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
