FixYa.com
Tags:
Ovens
Generic problem for all Ovens
How to find discontinued Dacor oven part?
posted by volena7 on Jul 20, 2008
I have a Dacor wall oven model CPO 130 (over 10 years old). The rotary switch pcb assy. part #82810 is not working correctly. LCD light in first baking position (bottom heat) stays always on even when dial is in "off" position. Sometimes in blinks even in second position (broil). To start the oven, I first have to push the memory botton. Other then that, everything works normal. I would like to buy a new switch board, but it is discontinued and I cannot find it anywhere. I am sure it must exist somewhere either new or used or remanufactured. Any advice would be appreciated. Thanks, Frank Volena
Comment by volena7, posted on Jul 21, 2008
Thanks. I wander why Dacor have the part #82810 listed but do not carry it.
I did look for the switch board "verywhere I could thik of, both by phone and Internet, including Dacor and their autorized service and parts providers, but always got the same answear: "The Part is discontinued and don't know where to find it".
I found a company that remanufactures oven control/switch boards, but they want my board. I don't want to send it to them, in case something happens to it, I have nothing.
Would not mind buying the part used or remanufactured as long as they don't want my part before I try theirs.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
captaynkyrk
Rank:Wiz Wiz
Rating: 84%, 40 votes
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Rating Locked! (?) volena7 has rated this solution as Thanks for Trying
This Problem Also Relates To: GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... GE JRP28 Electric Double Oven GE JTP28 Electric Double Oven GE JKP28 Electric Double Oven GE JKP85 Electric Double Oven GE JGRS06BK Gas Double Oven GE JRS04 Electric Single Oven
Can you Help with these Ovens problems?
GE JTP45 Electric Double Oven
Installing a GE Double Elec...
I have recently purchased a... Answer This...
Whirlpool RBS305PDS Electric Single Oven
oven code question
When I turn my oven on and it... Answer This...
Smeg SE250XUK Stainless Steel Electric Single...
Hotpoint oven heating element
The main heating element... Answer This...
Ovens
Problem with ignition
My Parkinson Cowan SG550WN gas... Answer This...
Ovens
Oven not working
I have a pyrolitic double oven.... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
