Question about Admiral AW22 Top Load Washer
Admiral Top loader leaking water
I have a Admiral top loading washing machine, model AAV7000AWW, that leaks water when it spins. It is leaking under the machine and it is from the area where the bleach dispenser is. It isn't bleach because the water is soapy and it happens even when I don't use bleach. The machine was recently moved over 300 miles. I don't know if that has anything to do with it. Any information would be helpful.
~Estelle
newstelle@cox.net
  • Anonymous Sep 22, 2008
    I have the same problem with water leaking out. Also, a loose drum and a high pitch sound when it spins. I also have bleach marks over my clothes even on loads where I don't use bleach.
    Problem Solver:
  • 10 Answers
Water inlet vale has internal malfunction
Posted on Oct 08, 2008
    New Friend:
Here's the problem, its a "clocking" (timer) problem. When the wash cycle is finished it is supposed to pump down the level of the water and then begin to spin. If the clocking is off it begins to spin and pump at the same moment. Centrifugal forces cause the water to rise up the outer edges of the tub until it breaches the top and leaks from under the machine. Some people notice a hot motor smell as it causes the motor to overwork trying to spin the heavy load due to the weight of the water. Solution: replace the Clock (Timer) Or my personal solution front loaders are on sale for $599.00 at all the box stores (WM2250CW)
Posted on Jun 26, 2013
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
Admiral aav7000aww water slowly leaks into tub when machine is off
You need to replace the water valve. here is a link to the part. Here is a video to show you how to replace it.
Nov 28, 2010 | Admiral AW22 Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Leaking water in washing machine
Front loader or Top Loader? If front loader you probably put to much in and at spin cycle the tub hit the hose to the pump and possibly got knocked off?
Oct 16, 2009 | Washing Machines
Water fills to overflowing without stop
replace the hose ..connects to tank other end goes under console to water level switch so no level control
Nov 16, 2008 | Admiral AW22 Top Load Washer
Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Sep 01, 2008 | Admiral AAV7000A
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Does not spin
the machine will agitate and pumpout the water but it will not spin
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
479 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
