Question about Dishwashers
Bosch Dishwasher SHU9925UC
Hi, Well, the water is plenty hot! It drains out and then fills up again and has actually leaked out all over my wood floors. Yikes! I turned off the water underneath the sink and that has prevented my washer from filling up and leaking. I am wondering if this was a coincidence because the overflowing dishwasher problem didn't happen until today after I repaired my leaky kitchen faucet. My husband also today used our wet/dry vac on the outside lines to clear the lines because our airconditioner drip pan was overflowing. He thought there was a clog somewhere and it seems to have fixed the problem. But then the dishwasher started malfunctioning directly after that. Is this just a coincidence? Is there a way I could just reset the dishwasher? Thanks for your help.
  • Juliana Lerman
    Juliana Lerman Jul 20, 2008
    Ok this is what I have done and found out so far. First I turned off the breaker to dishwasher. I then took off kick panel and vacuumed out all of the water in the white tray area underneath. When I turned the breaker back on I noticed the dishwasher filling up with water (even with the dishwasher power button turned off!). I think that my dishwasher will never end cycling because it is always refilling up with water. What should I do to stop the constant refilling problem?
    Guru:
  • 1,342 Answers
Reset is probably a key combination, not sure which one though. Would have to refer to the manual. Unplugging it for a while should also reset it. With all the water cycling and overflowing some water may have gotten into an area of the dishwasher where it shouldn't have.
Here's a post
where the user had a problem that sounds a lot like yours. Read the last paragraph to see how they resolved it.
Here's another link for diagrams, manuals and how to guides for your unit.
Hope this helps. Let me know if I can be of further assistance.
Posted on Jul 20, 2008
  • Georgia B
    Georgia B Jul 20, 2008
    Sounds like the fill valve may be defective. (Stuck Open)
    Part Number:
    AP3783031
    Here's a link to a site that tells you how to run diagnostic tests.
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: continued discussion about my Bosch SHU9925UC
Let's try the simplest reset, unplug from the mains for at least an hour. Thereafter, try/run and check for any error codes, any blinking lights or message display.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Pumps water in don't wash and pumps out again
Not sure whether a schematic will help unless you have some understanding of the location of the components. It would help if you are able to clarify what you mean by pumping in. Usually you should hear the water inlet valve turn on to let water in. Then the wash motor should run to churn the water around and then the drain pump should drain the water out. What is happening is the dishwasher is leaking water as soon as it fills. This causes the flood switch to turn on and that triggers the drain pump to empty the water. Usually Bosch dishwasher have an inline water leakage detector. Check under the sink where water inlet tap is located. There is a device connected through which the water get in. The hose is detecting leakage. Need actual model number of the dishwasher to investigate.
Apr 07, 2014 | Bosch Dishwashers
Continued discussion about my Bosch SHU9925UC
Jul 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Bosch SHU9925UC Built-in Dishwasher
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
My dish washer won't stop trying to drain
my dishwasher would fill up and start draining when washing watt should i do
Nov 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch dishwasher
My SHU9925UC/14 will not drain and leaks hot water from underneith.
Aug 30, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch shu9925
take bottom front panel off to expose the bottom tray. you will find there is water in it. mop water out and appliance will operate ok. turn off at mains first.
if fault reoccurs, you have a leak which will have to be traced
Dishwashers Logo
238 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
