Question about Kitchen Ranges
Maytag oven model MGR5755QDS oven is not igniting. cooktop and clock work. It is not on sabath mode. How can we repair ourselves.
  • 1 more comment
  • richliveshot Oct 20, 2008
    My maytag oven is model # MGR5755QDS oven is not igniting. No sounds but one click about 6 seconds after you set the temp. Then it just sits at 100 degrees. Cooktop, broil and clock work fine.The temp sencor seems to work. After I have it on broil and the oven warms, then go back and try to set it on bake, it does show the rise in the temperature. Theres nothing in the trouble shooting that seems to cover it.Well? What do you think?
    Thanks!
    Rich
  • joe159 Dec 21, 2008
    Mine is doing the same exact thing. I cleaned my oven a few days before this happened and don't know if that has anything to do with the problem.
    Joe
  • tspedden Mar 23, 2009
    I have the same problem with this model. The stovetop works fine but the oven will not ignite...help please
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Won't bake, but all else works
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
Posted on Dec 22, 2008
vijaydangwal
  • 137 Answers
SOURCE: My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Posted on Feb 25, 2010
  • 54 Answers
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
SOURCE: Maytag Gemini electric double oven: Oven Control
I have the same problem with my stove but I do have auto select for the lower stove as well as keep warm for the upper,is there a reset button?
Posted on Nov 21, 2010
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
Sabbath
Call Maytag Customer Support: 800-344-1274 and they will walk you through stepes needed to get out of Sabath mode.
May 22, 2013 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
Stove has quite loud bang when ignited
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
Stove and broil work, but bake mode wont light, temp reading stays at 100 and controls lock up.
Know it's kinda late. I had the problem in March and hadn't had time to get to it. I need my oven though. I'm thinking of looking at the igniter, replacing it. Don't want to get hit with a $200 repairman bill. What did you end up doing?
Feb 17, 2010 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
Oven will not ignite in bake mode. Broil function works.
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 12, 2009 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
Dec 22, 2008 | Kitchen Ranges
Top panel shows sABath
Someone has put the control into the sabbeth mode the oven will not work until you clear this from the control. The info to clear is in your use and care guide if not contact the manufacturer and they can help you. good luck
Dec 22, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
