Question about Car Audio & Video
Pioneer bus cable wiring - Car Audio & Video
    Scholar:
  • 94 Answers
You asked for it...
..it's a little complicated.
The pioneer IP bus uses a 2 wire differential signal for communication.
An equal level on both lines is a logical low while a high is encoded as a voltage difference of some 100mV.
I think a CANbus tranceiver should work here.
The data transfer is initiated by either the cd changer or the radio.The initiator generates a high pulse ( ca. 170us ) and a following low pulse ( ca 20us ).
Then the data transfer starts, a 1 is encoded as a high-low sequence with a duration of ap. 20us for both levels and a 0 consists of a 33us high and a 7us low pulse.
The data is now transfered in bytes with MSB first, the 8th bit is an odd parity bit.At the end of the 3rd and all following Bytes there is an additional bit inserted after the parity where the receiver acknowledges the transfer.
This is done by holding the data lines in a high state after the initiator sets them low.If this ack is missing the transfer is stopped.
The timings may vary because the real data is encoded in the pulse to space length relation.
The first 3Bytes seem to be some kind of device address.The changer I used transfered a 0x88,0x68,0x00 here while the radio sended 0x88,0x08,0x06.
The next 4 bits were always high. After that a size byte and then size bytes were transfered. The last byte in the transfer is a checksum generated adding the values of all data beginning with the 4bit sequence ( = 0x0F ).
In the following part I only will write the raw data excluding size and cheksum field.
Each command transfered was first answered by some acknowledge packet consisting of a single 0xA1.
(which looks like: 0x88 0x08 0x06 0xF 0x02 0xA1 0xB2 -> 0xB0 is the checksum ).
For now I just figured out some very basic things like the fields where time, track and disc number are encoded and also some
key codes the radio sends. There are many more fields in the packets where i still don't know the meaning of.
(I just got the radio from a friend for some days and so I couldn't do so much more on it ... however .. if somebody is intrested in some
more information and is wiling giving me a radio and a changer for some weeks I'll try to do some more .... )
I have also designed a small circuit using a AT90S2313 controller which can be used for logging the transfer through the pc serial port and also
to send commands.
The following packet sended by the changer contained the time disc and track information.
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Info command modus mcd disc min sec track cdt Data 0x61 0x10 0x06 0x01 0x20 0x04 0x16 0x01 0x06 0x01 0x00 0x00 0x01 0x00 0x3F 0x00 0x00 0x00 0xC0 0x48 modus:
Value 0x02 0x07 0x08 0x10 0x11 0x13 0x14 0x15 0x16 Info ready track blink pause ready and disc blink disc blink load and disc blink eject and disc blink load eject cdt: bit0: (1:cdtext),(0:normal)
The text information was encoded within this packet
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13-22 Info command modus disc track text seqence number text Data 0x61 0x10 0x06 0x01 0x20 0x04 0x38 0x09 0x00 0x06 0x00 0x00 0x00 0x00
Recommend link: Vitaliy's Page @ http://www.vitat.spb.ru/ with IP bus interface on AVR basis and more IP bus informations
Some transfer log files are available.
Posted on Jul 20, 2008
  • Philip Rowney
    Philip Rowney Jul 20, 2008
    OK.. that was a bit much and the data tables got mangled.
    Here's a good site if you just want to hack a MP3 player into your head unit.
    -->LINK<--
    Regards
    Philip
WIRING
yes there should be a wire indicating this connection as example when adding amp/seperate wire connection to turn on when radio is turned on/off
Apr 01, 2014 | Pioneer Cd Rb20 Auxiliary Input Adaptor
Hi, i have the ipod ipbus cable withouth the pioneer cd-ib100 unit. will i be able to play my ipod. this cable has a red and black cable PWR N EARTH which i have connected, this is for charging and does...
Do you have the actual CD-IB100 box from pioneer, or is it just cables and wires?
Make sure you have the IP bus cable plugged into the right port on the CD-IB100
Feb 06, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Which ipod adaptor do i require if i have a pioneer pioneer DEH-P80MP cd player, there are three possible one's? Pioneer CD-IB100, Pioneer CD-IB100ii, and the pioneer CD-I200 cable. im not sure which one i...
First, the CD-I200 is only compatible with Pioneer units that have a built-in iPod adaptor; the unit will say "iPod/iPhone ready". Your unit is not ipod/iphone ready. So, you have to use one of IB units, they are ipod adaptors with the IP Bus cable.
Sep 15, 2010 | Pioneer DEH-P80MP CD Player
Can you please tell me if and where I can get an adapter to join a pioneer cdx m50 multi changer to the lead in the boot of a jagaur xj 40
This vehicle is already pre-wired for an Alpine M-BUS CD Changer, if you look in the boot under the parcel shelf you should see a Alpine cd cable tucked behind the carpet. The Alpine unit will plug in and play without any adaptors. You will not be able to get the Pioneer to work unless you replace the radio system.
Nov 25, 2009 | Cell Phones
Wiring colour code
what is your email i will email you the diagram
Mark
Jul 18, 2008 | Pioneer CDX-P670 6-Disc CD Changer
Ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
May 24, 2008 | Car Audio & Video
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC N2 XM NavTraffic problem
Did you try to contact Pioneer and express the problem? May be you should check all of your XM tuner bus cable, XM antenna and power wires connection see if they became loose when you removed it last time.
Apr 17, 2007 | Pioneer AVIC-N2 Car DVD Player
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
Car Audio & Video Logo
240 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
