Question about X2Gen MG19MY 19" LCD Monitor
X2gen 19" monitor
When I turn it on, it shows half the screen, then a black panel, then the other part of the screen. I've tried adjusting it, but it does nothing.
Help
  • ronilduarte Oct 08, 2008
    same problem here, it happened after alternating betwenn half life and desktop area... I just formated and the problem persists....
    HELP =(
  • 348 Answers
Open the monitor there is a vertical ic which has small alluminium heat sink ckeck 12v supply to ic if present then remove ic & check 12v at same point if present then replace ic if absent then check 12v regulator ic if faulty replace it
Posted on Oct 27, 2008
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Black out
even i had this same problem.....its two 220uF25V capacitors and one 47uF35V capacitor located on the backlight inverter chip covered by a plastic shield. It works just fine now. Be sure you get the polarity right when soldering in the new capacitors. It is marked by a shaded in half of the outline on the board and a line on the new capacitor. This was on x2gen 19inch wide screen though so check the specs of the capacitors on yours first. They all together cost around $5 at Radioshack.
hope i was helpful thank you
hav a nice day
May 19, 2009 | X2Gen MG19MY 19" LCD Monitor
22" X2gen Screen Gone Black
Hi...there,
Well...You're out of lucks! Only mfg. carried this parts... But you can try to repaired it, by replaced a few busted capacitors... Good lucks!
Oct 30, 2008 | X2Gen MG19MY 19" LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Please please help me
sorry hon...can't be of any help...my monitor finally died...it was only 4 months old. What a drag!
I ended up having to purchase a new monitor. But this time I bought a dell...no problems now!
Oct 08, 2008 | X2Gen MG19MY 19" LCD Monitor
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor cannot be turned on
You will need to check the power adaptor for voltage , if that checks out then you will have to check the power circut in the monitor, look at the protection component and diodes in the power circut
Black screen
Hey...Benji,
It's seems your backlight inverter are burnt out...Get a new one..or repaired old one by yourself.
Here how it done...need to replaced a new capacitors. Good lucks!
Aug 19, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen Monitor
you should be able to go to your control panel and on sound speech and audio devices,click on it and you can adjust your volume there,after you adjust it remember to click apply,this should help.
Jul 04, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
