Question about Asko Washing Machines
I have gotten an asko standard washer #w6021/w6221 and didn't get a owners manual with it. It has button on the front & I am not sure how to operate it.
Problem solved
Posted on Jul 20, 2008
How long should wash cycles be? mine have gotten longer
Not an UNCOMMON complaint Rosemary Stein,
On the new machines "suds-sensors" control the "efficiency" of your machine...
If you check you OWNERS MANUAL I'm pretty sure
You need to run good grade "HE" detergent...
The reason being the "suds-sensors" will get messed up with BARGAIN detergents & become MORE IN-EFFICIENT.
Contemporary wisdom says "If you stop now and run some cleaner in your machine you can avoid costly serve charges".
Hope this helps!
May 06, 2016 | Asko W6021 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
How do I turn on my washer .. I cant read swedish
Hi dear.Please follow the link below to dowload the quick start guide.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/W6021-_E
I hope that solves your problem.Thanks.
Nov 03, 2010 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
I have an Asko front load washer W6221. I have
I had identical problem. I diagnosed it to be the motor brushes on the front of the motor. They have an off switch in them when they get worn out. Easy to check and replace. Remove front lower panel (two torx 20 screws). Brushes are visible and are held with two screws each. One on each side of motor. Remove two screws on each brush and unattach wire. Two new motor brushes were around $75. Literally tooke 30 minutes to replace. Hope this is your issue!
Oct 14, 2009 | Asko W6221 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
