Relax. Check the cord if it is connected properly. It might be that the plug is loosed, some wires are open or the outlet is defective. Try to plug to other outlet. If the problem persists. Look at the power diode if it is off the power supply is defective. Listen to the fan in the power supply inside the casing if it is working. If it is not, then the fuse is busted. If you can take the busted fuse out then ok otherwise, you the service of the technician. If you have AVR connected to it, check the AVR if it is working, check if the switch is on, the lights on etc, same thing also with UPS. Contact me then if the solutions are not working.
