My printer doesn't work - Office Equipment & Supplies
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    And I suppose when you go to the auto mechanic you tell him, it doesn't work, fix it.
    Please give us more details.
You ****, you bunch of assholes
Posted on Oct 17, 2008
Printer do not start
Try to unplug the power adapter (black box) at the back of the printer for about 1 minute. If it doesn't work, try to update the firmware of your printer:
If those steps doesn't work and your printer is still under warranty, please contact our technical support team to have the printer replaced.
Aug 16, 2012 | Lexmark Interact S605 All-in-One Color...
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
When I connect the printer esp5 to the computer it doesn't seem to recognize it, why?
remove the cable and insert again.if it doesn't work change the cable
Oct 29, 2011 | Kodak ESP 5 Printer
I have a problem with my HP Photosmart Pro B8850, when I try to printout an A3+ photo image, the printer doesn't recognize the A3+ paper size and provides a diagnostic of uncompatible paper size. The...
Many printers can detect where the movable partitions in a paper tray are. If they get moved from the "Letter" size mark, the printer will detect that and act accordingly. Make sure if your printer has the movable partition it/they are in the correct position.
You can download the user manual for HP Photosmart Pro B8850 from here
Hope this helps.
Please rate if this solution was helpful, thanks!
Jul 18, 2011 | Computers & Internet
My officejet 6210xi all in one, the scanner doesn;t work it's says need software or driver for work but web hp says the driver for this windows 7 install automatically, the printer and copier work good...
Windows 7 will just have the printer drivers for this unit by default. If you want to be able to scan, you should install the full version of the drivers which is available from the HP website. Just search for your model number, select the operating system, download and install.
Jun 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Computer can't communicate with printer
whatever be the OS, get into control panel, go to printers and see the printer that you are using is set as default,,, there would be a check mark on that printer icon,, if not make it default,, and try again, If you are using a usb cable connect the usb cable of the printer to the back usb ports and try,, use the printer driver disk that came with your computer, perform a reinstallation of the driver
Feb 05, 2009 | Lexmark X2470 All-In-One InkJet Printer
I put an envelope in the printer since then its doesn?t work, I tried to restart, change the drum and push in a paper by the special slot and it still doesn?t work. Just the motor is turning and the excess...
reinstall printer
then go into properties, click main, where it says TYPE click plain paper, where it says SIZE click on the envelope size you want to use, then click ok
Feb 02, 2009 | Brother HL-2040 Laser Printer
Epson 4800 set ink crtg error
Check the following information for reset the printer cartridge.......
hope this helps you.
Oct 30, 2008 | Office Equipment & Supplies
61 people viewed this question
