Question about HP PSC 1610 All-In-One InkJet Printer
HP printer can't scan pictures it says i need to install or run device software
  • Anonymous Jul 25, 2008
    seems like everytime I want to use scanner, it tells me I need to install drivers or something to that effect.  I install them and voila.  two weeks later, same thing.  very annoying.
    other than that everything else works fine with it.
I have the same problem. We need help with these **** products!!!
Posted on Aug 05, 2008
HOW DO YOU SCAN
Hello pjbenven!
To use the scan features, your device and computer must be connected and turned
on. The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running
Windows, look for the device icon in the system tray at the lower-right side of the
screen, near the clock. To verify this on a computer using the Mac OS, open the HP
Device Manager, and click Scan Picture. If a scanner is available, it will launch the HP
ScanPro application. If it is not available, a message appears to let you know that a
scanner was not found.
To send a scan to a program on a computer from the device control panel (direct
connect)
1.
Load the original on the scanner glass. For more information, see Load originals.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press right arrow to select the program that you want to use (such as the HP
photo and imaging software), and then press OK.
4. Press Start.
You can find more information on the serivece manual
http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
Jul 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
I am trying to scan from a HP Officejet Pro L7580. I am a bit of a technophobe and the printer is telling me No Scan Options Refer to device documentation which I havn't got. PLEASE advise me on how to...
Hello Mr.Johnson !
You can start a scan from a computer or from the control panel.
Here you will find a link that will take you to this printers service manual (device documentation) :
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Hope this can help you
You can contact me directly on:
eliteprintersolutions@gmail.com
Good Luck
Jul 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How do i get my printer hp photosmart c6180 set up with my computer so that i can scan pictures from it to my computer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01705280&lc=en&dlc=en&cc=us&lang=en&product=1153494
These instructions will help you install the HP software in Windows XP - make sure you choose the FULL driver install (explained on the link). The basic driver does not provide any HP scanning software.
If you want to scan pictures without installing any HP software, Windows has some built in scanning features.
For XP...
For Vista...
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
When i want to scan at the time press Scan button on HP officejet 4255 all in one a message shows "you need to install or run software or device
Install and run HP solution Center given in the full installation of software, the scan button will work thereafter.
Sep 24, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Want to scan pictures
install the complete software of ur device and then you will be able to scan images through software. you can download the software from www.hp.com also.
dont forget to vote...
Sep 13, 2009 | HP DeskJet F380 All-In-One Printer
Scanning
The 6180 memory device refers to the removable memory devices that can be loaded into the slots on the front of the machine, not the scanner. Your devices are configured wrong.
The scanner is a TWAIN device and therefore requires a Twain driver. Accessing Twain sources requires you to SELECT SOURCE for your scanning software.
Just un-install, re-boot, then re-install the drivers for the 6180. Make sure to allow the resident software that runs on your PC to run in the background.  HP needs the "ImageMonitor" and other software to run in order to "feed" your scanning software.
Oct 15, 2007 | HP Photosmart C6180 All-In-One InkJet...
CAN NOT SCAN FROM PRINTER TO COMPUTER
New Computer is it? Vista- yes? Big troubles with drivers for scanners from vista. Scanners have a built in processor that runs all its operations on command from the computer. Vista is not speaking the same language the scanner wants to hear. Got onto HP tech support- I don't hold out much hope for you re this.
Jul 08, 2007 | HP PSC 1610v All-in-One Printer
HP PSC 1610 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
