Question about Samsung HL-R4667W Rear Projection Television
Our Color TV is now Black & White
We bought this tv (Samsung DLP Hln617W) end of 2004 and have already had to replace the bulb. Now a couple days ago i'm watching and hear a pop and then the picture goes out, so i turned it off. Next day we turn it on and we have picture, but only in black and white (not a negative looking type of picture) just no color on the picture or any of the menu or control panels that are brought up on the screen. Any idea what might be the problem? Whatever it is, i sure hope it's not going to be another $500 repair. Thanks! While on, the TV made a "pop" sound, turn off, lights flashed. Turned the TV back on, and now it is a black and white (full grey scale) TV; but no color.
  • 2 more comments
  • sjdances Jul 24, 2008
    Of course its a hardware problem. This solution was worthless. I am looking for more specific advice.
    TV is a Samsumg HL-R4677W. Everthing else is ok except the color. Is this problem caused by a broke color wheel? Does this model even have color wheel? Did a board burn out? If so which board would only effect the color?
    I am not the first reporter of this problem, several others seemed to have experienced the same issue and I am hoping to learn from their experience. My goal is find out the possible causes, so that when I contact repair services I can get an accurate estimate of the repair cost.
  • sjdances Jul 25, 2008
    Output is in black and white not matter what the input source.
  • sjdances Aug 02, 2008
    The problem was a broken color wheel.
  • 813 Answers
Cak the capacitor of the ckt bord if damged then replace it
Posted on Aug 02, 2008
  • sandip panchal
    sandip panchal Aug 02, 2008
    if problem occers u need to go witha professnl tv repairer
    Genius:
  • 1,269 Answers
The sound you heard was definitely a blown capacitor inside. That's the reason why the tv is still functioning with gray screen. Otherwise, if some vital part was blown up, it wouldn't turn on at all. I had the same experience and it was just a bloated capacitor on the circuit. If you can do basic electronic soldering, that's good, all you need to do is check the circuit board of your tv and look for a burnt component. If you can't do it, bring your tv to the nearest electronic appliances repair stations. It won't cost you much.
Posted on Jul 25, 2008
    Genius:
  • 1,665 Answers
1) check the voltage (with no aerial signal) on the collector of all three video output transistors (on the crt base) they should be +-5v of each other if one is different, then swap over this transistor with one of the other two and if color changes, its the transistor, If not then I use a 2k-4k wirewound and touch it from each collector to chassis in turn, and watch the screen (I use a mirror) each color should be equally bright with flyback lines, if not its probably the tube (CRT) faulty.
2) If all of tests are ok, then I find the three wires coming up from the the main pcb to the crt base panel and swap over the green/red and see if the color cast changes
If yes then its the chip on the main board, If no its on the crt base board, so check values of all the resistors there.
  • 1,498 Answers
I know you're inundated and this is a little outside the box.
This is not a solution to your problem. It addresses the symptoms not the cause. But if the symptoms go away.....?
It will take about 30 seconds to try.
If you get into your 'MENU'
There is an option for Color Weakness Enhancement
- It allows a user to 'boost' the Red, Green and Blue.
To try it out:
  • Select it
  • Choose ON
  • Slide the color bars to the right.
If it doesn't work, oh well, there goes a minute you'll never get back. It was worth a shot though.
If it does work.....
Mike
    Genius:
  • 1,011 Answers
Sir,
Be sure to connect this TV directly to an AC wall outlet. If the TV's AC plug is connected to a cable box or other source, it will not allow for proper cool down time. Also u must check out if any convergence ic's is working or not? so i think this is the main problem. u must replace the convergence ic's for better picture.
Thanks
Good luck
Don't forget to rate the solution
  • 105 Answers
I think there may be some problem with a capacitor used in it so try to check the circuit
    Genius:
  • 1,226 Answers
Since the TV still functioning got problems in color, There should be a further check in the capacitor , Even though playing from DVD player movie or CD movies it is the same output?
There might be some loss connection in some soldered connection. You can do re-soldered all the part in the board. just re-soldered it.
if not resolved capacitor near the vertical and horizontal board got leak.
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 27, 2008
    I think it is just a matter of adjustment. see your manual for the color adjustment and brightness of the TV.
  • 2,071 Answers
My response to this was to “reboot” the television. To do this, you must actually unplug it from the wall. Televisions and other electronic devices don’t actually power down completely when you turn off the power switch. Unplug it (after powering it off and waiting for the fan to stop!), wait a few minutes, plug it back in, turn it on.If still nothing happens then the problem like the black and white problem is probably a bad DMD control board. These cost about $250. So with a new lamp, I’m looking at almost $500 in parts only.
Try to the life hours of your lamp by using ,service mode on Samsung DLP TVs, simply turn your system off, then use the remote and press the following buttons with about .5 to .75 seconds delay between presses: MUTE-1-8-2-POWER. Once in the service menu, select the bottom item, Options, and from there you can reset the lamp counter.Never played with any of these settings. I’d strongly caution against any “curiosity tweaks” in there.
hope this may help;
Regard,
  • 304 Answers
The pop you heard was a component suffering fatal failure. If you are comfortable opening the unit and looking around the exact component with be easy to spot. It will be the blackened one that appears to have exploded.This is usually very easy to fix, simple identify the component and its exact value and replace it. Look around it for any other components that apear to be damaged or look like they got too hot and replace them too. Even if you can not handle swapping out the parts yourself, You will at least be able to let the repair man know that you know what parts have to be replaced and how cheap they are. This will make the repairman think twice before over charging you for the simple swap job. He will know you know a little some thing and will be reluctant to price gouge you. Anyway, This is the best info I can provide by typing. If you need more help feel free to ask me for more help. I you find this helpful.
George
Posted on Jul 24, 2008
  • 3,037 Answers
The color wheel went out. It is pretty simple to replace. I will find the directions that are online that I always give people to show them how to fix this themselves.
    Master:
  • 382 Answers
I hope the circuit board has been affected by a power surge or any short circuit which has caused this problem!..A burnt Ic or resistor might need some replacement..If nothing went really wrong then im really sure it wont be a $500 repair at all..So relax and hope for the best..Take ur TV for service at a nearby store who can easily repair it n put ur Tv back to condition..Hope this helps you out!!..Thank you..
Regards!!..
Posted on Jul 23, 2008
  • 1 more comment
  • Natesan Sabesan
    Natesan Sabesan Jul 23, 2008
    Btw if your going to your Tv company's service centre dont forget to claim the Warranty buddy.. :)
  • Natesan Sabesan
    Natesan Sabesan Jul 24, 2008
    Yeah exactly well we cannot accurately say without seeing your device as which board burn out would have caused this because there are several possiblitiess..So keep your fingers crossed and call for a Service person hoping that he wont charge much buddy..
    Dont forget to rate the solution..!!!..Thank you!!..
    Regards!!...
  • Natesan Sabesan
    Natesan Sabesan Aug 02, 2008
    Broken colour wheel doesnt cost much to get replaced so you can very call a service person to get it replaced!!..
  • Samsung Master
  • 1,879 Answers
Greetings,
Definitely bound for repair since something"popped" inside.
Are you familiar with electronics troubleshooting ?
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
  • 10,594 Answers
In my openion, You should contact concern service center for proper repair because your tv has hardware damaged due to over voltage inside.
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My DLP617W is black and white today and tried everything I know, does not work. Any suggestions ? Thank you.
i'm probably sure that is the dmd let me know a couple of things.
TV make's were noises? the white spots comes and go?
it look like this?
Dec 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
it sounds like the main board to me, I can purchase them if you want one let me know
May 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-R4667W Rear Projection Television Logo
174 people viewed this question
Henry  Thomas
Henry Thomas
