Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Too much water where is fill switch
Where is the fill switch on this model ld12aw2
I cant give you a solution for yours. but my Lg dishwasher was leaking from the same spot. THey declaired it lemon and replaced it! We have had are new Lg for a week and it started leaking from the same spot.Im really starting to think there a piece- of-s..t. good luck
Posted on Jul 27, 2008
    Problem Solver:
  • 10 Answers
The fill switch is actually a pressure swith located at the bottom front of the d/w.
take care.
Posted on Jul 22, 2008
My washer fills fills with water but doesn't agitate. Water just keeps running, then leaks out the back
Sandy, it's not a matter of recognizing (or not) the wash cycle. There is a pressure switch (behind the water level selector) which determines when the water has reached the correct height. If this switch is defective, the machine will continue to fill.
If you can give me the model number of your machine, I can provide you with the part number of the switch. Depending on your model, replacement of the switch is not difficult.
Feb 01, 2015 | Washing Machines
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Awhile back I had FixYa help me with my washer. It would fill up with water and then just stop. It turned out to be the lid switch. Now about a month or so later I went to wash a load of clothes and again...
Hi.
If the lid switch is OK and there is water getting into the machine, then test and replace the pressure switch that detects water level.
Here the part:SUB 12002304 (Water Level Switch Kit)
Part is nr 6 in this diagram.
Also test the inlet valve to ensure that dual inlet is working. If hot is not filling, the machine will not complete filling.
A technician can swap valve contacts to find out if
both valves are opening.
If there is no filling at all, check the inlet valve and inlet duct:Water Inlet Valve.
Inlet valve is at the back of the appliance. It can be tested reading Ohms at terminals.
Aug 11, 2010 | Maytag LSE7806A Top Load Stacked...
New install, used machine, need an old manual.
I'm too late for you but others could be helped. With the power off' make sure the timing cams are set to the beginning of cycle, Then push the cams with a finger untill the fill cam switch just activates. Then put the power on,close and latch door and water should enter the booster. You might have to do this 2 times to get water at correct level inside machine. When the cycle lite goes off check for water inside machine. If water level is too high, then take some water out with a cup.
Jan 19, 2010 | Moyer Diebel 401HT Dishwasher
Maytag Washer Just Stopped After it Filled With Water (Timer?)
Cant rule out the timer but I suspect first check the lid switch. The timer and other components are fed from the lid switch on most models. Just put the2 wires together and reapply power if it works replace the lid switch. If not you'll have to have a wire diagram to know where to check next, but your water level switch "fill switch" could be at fault. it stops the water valve 1 way and can energize the rest of the circuits the other way. It may not be closing in the "full" direction. Again this switch if so wired will have 3 wires on it.
Mar 24, 2009 | Maytag Washing Machines
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG LD12AW2 Dishwasher overflowing
On the LG LD-12AW2 model, there is a float assembly just behind the wall where the water inlet port is located inside the unit.
When that float (or the micro-switch inside it) fails, water will continue to flow in without stopping . That causes the overflowing.
Post back here if you are looking for more specific guidance.
Good Luck!
Dec 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD12AW2 leaking
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Oct 28, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
163 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
