Question about Refrigerators
GE Refrigerator Model TBX22PC ice dispenser works one time but not another. How do I troubleshoot? Had problem last year GE repair person hit the back of the dispenser with his hand and it has worked until now.
  • Anonymous Aug 11, 2008
    makes ice but wont come out
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
SOURCE: GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Posted on Sep 11, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
Clicking sound, not cold, water/ice dispenser broken
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | GE Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Our side be side ge fridge is giving us a problem...power is ok as lights are on and freezer/ice cube & water dispenser is working ok...but regular fridge side is warming up...it has always been set...
heatman101
Mar 30, 2011 | GE Refrigerators
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
gfhjsf
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE side-by-side has 2 problems, maybe related?
i have a 29 sidexside Ge refrigerator. tonight when i was trying to get ice,it stopped working and after a few seconds,with a clock like sound it began to work again.but everytime i try to get ice it happens again.last year i chanege the board. what is the problem,can i fix it?
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
May 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
