LG DLE5932W Electric Dryer Logo
Posted on Jan 31, 2011
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you are running multiple loads right after each other it over heats fairly often. Can you give me an idea what is wrong? I religiously clean the lint trap and clean the vent duct out a couple times a year and it has little effect.
Anonymous
Level 1:
Champion:
  • Contributor 266 Answers
  • Posted on Jan 31, 2011
Anonymous
Contributor
Level 1:
Champion:
Answers
266
Questions
Helped
54352
Points
6
This could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
I have a LG dryer model DLE5932W that will not shut off on its own
will it shut off if you run it on time only mode?
Aug 31, 2016 • LG Dryers
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
The dryer heats up, but not hot enough to dry the clothes. Have cleaned all the vents and have good air flow.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
The check filter light is on. The clothes are not
The check filter light, is default message LG was put in place. No problem there. As for the clothes, I'd need some more infomation, what settings are you using on your dryer? I'll need to know if your using sensor dry, or manual dry.
DLE5932W - Not shutting off when clothes are dry - keeps running
You have a computer control board problem and needs to be replaced.  The internal program has a problem and won't time down properly.
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 • Dryers
Dryer
things to take into account- are all the filters/ customer cleaning service parts clear?
is there good airflow and are you overloading the unit? there should only be 1 heater element controlled by a reduced heat switch.
2answers
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site WWW.LGSERVICE.com. They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
