Question about Dishwashers
My Bosch SHU9925UC dishwasher will not stop cycling and come to an end. I also noticed that a couple of weeks ago it stopped beeping to signal the end of the wash. Can anyone help me please? Thanks for any ideas.
  • 6,487 Answers
Go check this link it will help you http://www.applianceaid.com/boschDW.html#run
Hope that helps.........
Posted on Jul 20, 2008
  • Mark Gil
    Mark Gil Jul 20, 2008
    Run the diagnostic program - power on button while depressing power scrub and regular wash. Press again to run diagnostic set.
    You can find the complete details on teh link that I gave you.
    Good luck.......
  • 319 Answers
The cycle will not finish if the water temperature is not high enough. You may have a faulty heating element. Please check for obvious defects in this component first. Let me know what you find.
Brian
    Brigadier General:
  • 6,966 Answers
Initially sounds like a bad timer switch or controller board. A couple of questions pls:
  1. any recent power interruption;
  2. how old is the unit;
  3. anything out of the ordinary other than those posted;
  4. how is the water pressure
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 19,396 Answers
It is probably a faulty control panel, usually you have to replace it.
    Guru:
  • 1,342 Answers
From the Appliance Repair Clinic:
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
Jan 08, 2014 | Bosch SHU9926UC Built-in Dishwasher
Incessant end of cycle beep. Can I stop it? My new Bosch shx68p05uc drives us nuts. My 88 year old mother-in-law sleeps near the kitchen and I cannot run this dishwasher at night due to this darn...
Welcome to FixYa.
To turn the volume down of the signal or to turn it off entirely is as follows...
Hope that solves your incessant beeping problem. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided here as well as a brief testimony is appreciated.
Regards,
Macmarkus :)
Apr 19, 2011 | Bosch SHX68P05UC Dishwasher
Want to stop buschh dishwasher shx43p15uc from beeping at end of cycle
To turn off the cycle completion signal on a Bosch dishwasher, please do the following:
1. Press and hold the right "CANCEL/DRAIN" button then press and hold the "ON/OFF" button
2. When the light above the "CANCEL/DRAIN" button illuminates and the beeping starts, release both buttons
3. Press the right "CANCEL/DRAIN" button repeatedly until the tone is at the desired volume, i.e. silent
4. Press the "ON/OFF" button again to confirm/set the desired volume.
Happy Holidays!
BElectric
Dec 24, 2010 | Dishwashers
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Shv6803uc bosch dishwasher won't stop beeping at end of cycle, I believe this is about 6 yrs old but I don't have the manual.  thank you
CALL 800 944 2904 THEY WILL WALK YOU THROUGH OTHER WISE OPEN THE DOOR AT END OF CYCLE AND BEEPING WILL STOP
Jul 20, 2009 | Bosch Dishwashers
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Under counter Bosch,grinding noise
It sound like a pump issue. Open the service panel, remove the pump and try to rotate its pulley manually, it should turn freely.In case it doesn't,check if it is clear from any foreign object or it should be replaced. Good luck !
Sep 06, 2007 | Bosch 24 in. SHX33A02 / SHX33A06...
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
