Question about Insignia IS-PDVD10 Portable DVD Player
Dvd battery will not hold a charge after being charged for days????
    Novelist:
  • 170 Answers
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Posted on Jul 29, 2008
Why the battery of my unit is not charging? and When do i know the rechargeable battery is to be replaced?Coy
You need to replace the battery when it no longer charges or when the battery won't hold a charge and dies quickly. the charging symbol will light, as the charger is working, but in your case, the battery is not accepting or holding the charge.
Is this a hand-held DVD player?
Oct 23, 2015 | Televison & Video
Battery won't hold a full charge
batteries don't have a life forever. And no one can predict the life time of a battery.
So many factors influence the lifetime. But if it is draining very fast, this mostly means it has reached the end of life. If the camera does not get excessive hot, it has nothing to do with the camera. It is just you need a new battery.
To keep a battery in shape for a longer time you should charge it also when the camera is not used. Like at least 4 times a year. Always charge the battery a day before you plan to use it. Don't over charge, like charging it every day. Don't leave it in the bright sun or on a hot place.
A new battery, should be charged and discharged a few times, before it gets a full charge.
The "New" battery you bought, could be in stock for a long time. Special when you could buy it very cheap.
Perhaps in a few days you say, he the battery works fine now. But if you did charge it 3 or more times and it still does not hold a charge. send the battery back (I hope you bought one with warranty)
Aug 14, 2014 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced.
When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
The battery doesn't seem to be holding a charge. Not sure what I am doing wrong. When I charge the battery should the device on on or off mode?
When u charging the battery of the portable DVD player,DVD player it should be in the off mode and have a solid LED light indication on.
Nov 08, 2010 | Haier Portable DVD Player PDVD7
I have a 92 camaro rs tbi and the alternator and the battery went bad and i just replaced them 2 days ago and now the battery is dead again and after i charge the battery it still wont hold a charge the...
take it back they have to replace it,they either have a 60-90 day warrenty also see if battery cables are tight.if you have a chrger see if battery holds a charge.
Aug 29, 2010 | Chevrolet Camaro Cars & Trucks
My Portable DVD Player Battery can't hold a charge
Rechargeable batteries can only be recharged so many times. They begin to slowly lose their capacity after about the first 5 charges until ultimately it won't hold a charge anymore. It appears that this is your problem. Look for a model number on the battery & do a Google search for it if you want to try & replace it. You might also find it is cheaper to buy a whole new DVD player than it is to buy a replacement battery.
May 20, 2009 | Protron 7" PORTABLE DVD
MY BATTERY IS NOT HOLDING A CHARGE LONG ENOUGH TO WATCH A 2HR MOVIE. HOW DO I TELL IF IT IS THE BATTERY OR THE CHARGER.     S/N;210FD140335 DVD MODELPVS12701                        THANK...
There are only a few possible reasons...
  1. The battery is not being charged properly
  2. The battery needs to be cycled
  3. The batter is defective
Option 1 - If available try another charger
Option 2 - Run the device until the battery totally dead\depleated of power. Then charge the battery for the maximum charge time suggested by the manufacturer. If you do not have the manual and cannot find their website then attempt to charge the unit for apptox 24 hours. If this does not work then it is either option 1 or 2.
Option 3 - If available try another battery in the device and see if it is being charged and if it is holding the charge. If Yes, then the battery need to be replaced.
Jan 22, 2009 | TruTech PVS12701 Portable DVD Player
Dvd player does not hold a charge ( has a new battery )
take a voltmeter and test charger or borrow a known good one from a friend if you know anyone who has one , sounds like bad charger word--- it is much better to run all rechargeable devices mostly all the way down before recharging as these batteries will do what is know as establish memory and will shorten battery life do not leave on charge except when charge is needed
Nov 18, 2008 | Polaroid FLM-3732 Television
Battery not holding charge
I had the exact problem as the other two above but resolved the situation as follows: I connected the battery to the charger and switched the power on. The charge light on the battery glowed 'red' as it should and some time later, not as long as it should have been, the light changed to 'green' indicating it was fully charged. At this point I removed the charge lead from the battery and then replacedit. The charge light reverted to 'red' again. When it eventually changed to 'green' I repeated the above step and did so for the next 18 hours. I then connected the battery to the player and played a dvd 1hr 55min film. It worked fine. I hope the solution works for yuo!!
Nov 24, 2007 | Mustek MP72 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
272 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
