Question about Dryers
Dryer stopped working in mid-cycle
Is there a reset switch for the Maytag Legacy Series Dryers? This dryer is about 4 years old. I tripped the breakers, and this did not fix the problem. I hear there is a reset switch. I opened the panel on the back of the dryer, near the top where the controls are, but didn't see anything that resembled a possible reset switch. Should I be looking somewhere else?
Thank you.
  • kbz_angel Jul 20, 2008
    the above dryer is a Maytag Legacy Series Model #SDG515DAWW. Approximately 4 years old.
    Okay, thank you. I don't know if that is a job this girl can handle, but I'll find someone who can. :-)
    Where would I purchase something like that? Home Depot? Sears? I have no idea. Maybe through Maytag directly? I'll google it.
    Thank you very much for your helpful comment.
    Genius:
  • 1,028 Answers
More than likely a thermal fuse has blown ..i believe on that model you pop the clips holding top down element is on rear wall of dryer thermal fuse has 2 white wires going to it and is mounted on side of element the big thermostat on top and the fuse come in a kit and should be changed together
Posted on Jul 20, 2008
Maytag legacy series quiet 100 electric dryer. Nothing. It is just dead. All power is connected properly. Just stopped working.
try looking on the back and on the bottom of the dryer and see if there's a reset button there
Dec 12, 2014 | Dryers
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
I have a Maytag Legacy Series and I can't get my lanudry dry. What setting do I need to use to get towels & jenas dry?
Check your venting and make sure it isn't kinked or dirty. The vent is the 4" hose connected on to the back of the dryer. Many times, lint will stop the vent up all the way to the out doors and your dryer will overheat and take a long time to dry the clothes due to limit switches tripping because of excessive heat. Hope this will help you.
Apr 13, 2011 | Dryers
Electric dryer keeps tripping reset button on bottom works for about 2 load then trips it s a fisher pakel top load dryer about 4 yrs old
main drive motor problemely has dust in start switch in the motor an the motor is staying on the start cycle an not switching to the run cycle you have to take the motor apart an clean it or you may be able to air blow the dust out
Dec 17, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
I have a Maytag PYG3200AWW and it won't start.
Sounds like a problem with a limit control switch. Some are manual reset and some are automatic . Not sure about yours. They are located of course, in-line within the wiring harness limiting the amount of heat build-up within the machine. If yours had been running with a stopped up, or patially stopped up vent, (and your limit swithch IS AUTO reset,) then the switch could have been cycling the heat numerous times, over that period, preventing overtemperature conditions. This would weaken the switch because it is a safety device and not actually a cycling device. Also, in the vent exhaust, @ the back of the machine there may be a limit switch. And of course, it could always be the start button..........
Jul 27, 2009 | Maytag MGD6300T Gas Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Dryers Logo
459 people viewed this question
Top Dryers Experts
