Question about Dell 924 All-in-One InkJet Printer
Want Print trying to print but it want print
  • berniesmll Jul 22, 2008
    the priter tells me that it has loose contact but i have ghanged every thing over and it is still the same also it is showing low ink
Can not print printer and laptop not connected
Posted on Aug 03, 2008
Can't print. local print spool not working
Try the steps below to clear the print queue and restart your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 11, 2012 | Lexmark X5495 Printer
I need to restart my computer everytime i want to print
Sounds like you have print jobs stuck in the print queue. Try deleting all documents in the queue and resending print job. Some print drivers choak on PDF documents. Try updating the print driver by download it from the manufacturer.
Try deleting printer then re-installing printer and updating the print driver.
Sep 21, 2011 | HP LaserJet P3005 Printer
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
Jun 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
4 Press Select.
clogged nozzles.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
5 Click Print.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
4 Remove the old cartridges
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
The setup wizzard does not see the print server
Is your print server and the computer connected to the router with the Ethernet cable. if not then connect both the print server and computer to the router with the cable.
then try it.
you can press the reset button on the print server for 5 to 10 seconds and you will get a print out ( printer should be connected to the print server).
on this print. you will find the IP address of the print server.
try to open the print server set up interface of the print server.
Click Here for more information.
Oct 05, 2009 | Computers & Internet
How do I change HP 5610 print cartridges.
gtabseps.gif Introduction Follow the instructions below to replace the print cartridges. This document applies to the following products:
  • 5605
  • 5608
  • 5610, 5610v, 5610xi
Replace the print cartridges Step one: Remove the print cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on. Figure 1: Press the On button to turn the product on c00442142.gif 1 - On button CAUTION: If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Figure 2: Open the access door c00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. Figure 3: The print carriage c00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper position c00442144.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Jun 21, 2008 | Office Equipment & Supplies
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
Dell 924 All-in-One InkJet Printer Logo
16 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
