Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
My ionic breeze GP won't turn on - Sharper Image Ionic Breeze GP SI730 Air Purifier
  • 3 more comments
  • Anonymous Aug 04, 2008
    my ionic breeze died. no lights go on and i've tried different outlets. just learned sharper image in is bk. now what? buy a new air purifier? bp71484@verizon.net
  • Anonymous Aug 09, 2008
    Same problem, my Ionic Breeze will no longer turn on. Cleaned everything but not getting any power to it??
  • zuomo Aug 23, 2008
    Same issue... I own 2 and 1 just died. No lights, no power. It was well maintained. If anyone has had success fixing it DIY or a repair service I sure would appreciate any assistance.
    Thanks
    zuomo@yahoo.com
  • Anonymous Oct 16, 2008
    I have Ionic Breeze GP professional series and it wont turn on
  • Anonymous Oct 27, 2008
    I have the same problem, we have 2 Ionic Breeze GP's and they both just stopped working. No light indicators at all. The first GP died about 3 months ago, the second GP died a month later. tried different outlets. Is there a reset switch or fuse in it someplace that needs to be switched out?
  • 6 Answers
Okay, after working on my Ionic Breeze Quadra I have fixed it. My problem was it wouldn't turn on even though the fins were clean.
1. Unplug
2. Turn the machine upside down (there are 4 screws holding the bottom stand on) remove the screws
3. once bottom is off there are 2 screws sideways helping the hold the 2 sides together. Remove those 2 screws.
4. Turn the machine uprgiht and remove the middle fins (the ones you clean)
5. Remove the 4 screws that are deep in the 4 holes when you look down inside (you can't see the screws, I had to feel for them with a phillips head narrow screwdriver)
(it will be easier if your screwdriver has magnetic head for next step.)
6. after removing the 4 screws gently work lose the top (part that has the little lights and turn on push switch)
7. turn the breeze on its side, you will find about 5 or 6 tiny screws holding the two sides of the outside louver case together. Remove all these screws. You will be thankful for the magnetic end, I have small fingers and still had a problem catching the little screws.
8. You want to take off the screws from both sides but only remove one side.
9. Being careful of the wires (I left that side alone) I worked from the wire free side and using a bottle of rubbing alcohal and lots and lots of q-tips I gentle cleaned off all the gunk on all the little metal pieces at the bottom of the breeze (on the inside where the wires are). Clean as good as you can, you will find the metal pieces covered with what looks like tar but it comes off with the alcohal.
10. Using a can of 'canned air' like you'd use for a computer, gently blow the rest of the breeze parts getting all the dust away but being careful not to damage the electronics. (there are a lot of little computer boards). I didn't find any dust in the electrical parts in the very bottom of the breeze, just above where the fins are and some at the top where the controls are.
11. I cleaned the 1/2 I took completely off with some rubbing alcohal, gets that **** off pretty good but didn't mess with the side with the wires, just blew the dust out, gently cleaned a bit and on the outside.
12. To put back together, first I gently put the outer middle pieces together and then gently put the control top back on and replaced those 4 screws. Then I put the 10 or 12 tiny screws back into the middle, then the 2 screws in the bottom sides and 4 screws putting the stand back on. I stood it up, plugged it in (make sure its dry) and turned it on and the light came on and it is working great.
I've had mine for 3 years so I think they occasionally need a thorough cleaning. Except for the canned air I bought nothing else. Everyone has rubbing alcohal and q-tips in their homes. When I first started I didn't know how to dismantle it and tried to clean the inside with long q-tips but it was too hard. Those little metal pieces in the bottom make some sort of connection to the fins we pull out and clean so I guess they need good contact.
I hope I've helped all of you with the problem of the Ionic Breeze Quadra and I suspect any other iconic breeze type machine by sharper image pretty much comes apart the same way and may have the same problems. I don't know how to post this so that everyone can see it as a general solution. Maybe you guys at FixYa can help with that. --- Harry Potter Without the Wand (and a female to boot!)
Posted on Mar 08, 2009
    Scholar:
  • 62 Answers
I posted a solution to a similar problem I had with my Ionic Breeze GP. I was able to replace a bad switch and get the unit working again. Perhaps the following article will help you:
http://www.fixya.com/support/t123864-ionic_breeze_3_0_repair
Posted on Nov 13, 2008
LOL...mine too...it's like the device was like so sad about it's company's fate, it quit!
Posted on Nov 01, 2008
I need to replace the bulb for ionic breeze air purifier S1830
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
this bulb is available on ebay for under $11.00. The release tab for the cover is at the bottom of the cover and it comes off pretty easy. Once the cover is off you turn the lamp 1/4 turn (two clicks) and slide it from it's fixture.
Jul 01, 2009 | Sharper Image Professional Plus Ionic...
Where can I buy replacement grid for ionic breeze professional series model S1831?
Item number on ebay is: 220444965077
$10.99 plus around $5 to ship.
Pull up on the tab on the bottom of the front filter and pull up. You then should be looking at the bulb, which you will turn 1/4 turn (2 clicks). You should then be able to pull the bulb out.
Hope this was helpful.
Jun 10, 2009 | Sharper Image Professional Plus Ionic...
Need Blubs for the Ionic Breeze GP
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} You can purchase a bulb for the GP on ebay for under $11, which is really a good price considering what you would have paid from Sharper Image. Installation is easy, you just pull up on the tab on the bottom of the filter and pull up. When you are looking at the bulb, turn it 1/4 turn, (2 clicks) and pull it out. That is all there is to it. Item Number: 220444965077
May 24, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Owner's manual for Ionic Breeze GP
does anyone have (I hope) a free manual for an ionic breeze quadra? I have had this fo awhile but lost the manual
Nov 08, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze gp grid
This is where you go to get what you need......
Hope this helps....good luck and thanks for rating my effort....the Fang.
May 31, 2008 | Sharper Image Extra Grid for Ionic Breeze...
Ionic breeze "GP professional Series" no pwer
Hi.
I don't know if you are still using the Ionic breeze air purifier, but I wanted to call your attention about some important concern related to use of ionic purifiers.
Please read the brief article here: http://www.fixya.com/support/r5303535-ionic_breeze_parts_repair
May 29, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
356 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
