I have a philips powervision TV - Have lost the Manual aqnd I want to tune it into new channels. Cheers! Mike
  • jenitebb Jan 02, 2009
    I have the same problem. Same tv but would like to put the tv on av so I can set the set top box up but do not know how???
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I found a NTSC 3.58/4.43 in the street my friends and I don't know how to connect it to the antenna without a remote control is there anyway you can without a remote
Posted on Jul 08, 2017
Slinteriors
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
SOURCE: I have been given a
Found a download PDF manual on Philips' website
Posted on Jun 13, 2008
  • 52 Answers
SOURCE: I have a Philips powervision
your tv should be a multisystem. Is there an option between NTSC and PAL on your TV when you tried the menu on your remote?
Posted on Jun 28, 2008
  • 1779 Answers
SOURCE: No colour, contrast or volume memory. Channel memory OK, have fitted new battery.
Sounds like the eprom! I don,t have that manual in front of me but if it has a 8 pin eprom, try this, remove it and see if your settings are available and operational,( the ones in question) if they are then it is defective.
Posted on Apr 28, 2009
  • 150 Answers
SOURCE: Unable to tune the channels into the tv.
send me a picture of the front panel I will tell you how.
I got this Philips Powervision old Projection TVbut without remote; how can I tune the channels since the buttons are not applicable.
Check online for universal remotes.
Most will have downloadable instruction to see
if your model is listed and has a code.
If so problem solved.
Mar 09, 2015 | Philips Televison & Video
I dont know how to operate the install button/ have no manual
My suggestion is to look online and try to find one there.
Aug 19, 2014 | Philips Televison & Video
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
I have lost the red colour. Can I adjust this somehow?
OK. IF THE RED COLUR HAS GONE, YOU PROBABLY NEED TO CALL AN EXPERT. LIKE I TOLD SOMEONE ELSE, IF YOU USE A CABLE BOX, ITS PROBABLY THE CABLE BOX. ALL YOU NEED TO DO IS HAVE THEM LOOK AT YOUR TV AND YOUR CABLE BOX IF YOU HAVE ONE, AND/OR BUY A NEW TV AND/OR CABLE BOX.
May 31, 2009 | Televison & Video
Phillips cd recorder
try tuning the unit, into the channels. if it,s recording one channel. it could be the possibility that the dvd is tuned in to the t/v incorrectly. refer to the users manual/guide.
on setting up the player to the t/v channels.
Mike @ Compurepair.
Jul 02, 2008 | Philips CDR770 CD Recorder
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Philips tv/video combi 14pv182
Download the manual here http://www.usersmanualguide.com/philips/tv__tv_-_vcr_combi/14pv162_08
Aug 19, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Televison & Video Logo
364 people viewed this question
Top Televison & Video Experts
