Question about MicroBoards PF-2 InkJet Printer
Pf-2 disc feed problem
No disc will feed, I need to manually force the disc on the belt to print
  • davetv28 Jan 14, 2009
    My PF-2 prints just fine- one disc at a time. When it comes time to drop a blank disc- the drop mechanism goes "thunk, thunk, thunk, thunk, thunk" likes it's trying hard to allow a disc to drop but without success. I'm using the same media as always. The printer was working fine one day, next day not.
I had the same problem. Had to call microboards, (952) 556-1639, and order a chip for $20.00. Put it in myself and now it work fine.
Posted on Jul 29, 2009
The loader on the pf-2 is controlled by the large chip below the loader, the current version is "V2" also there is a small micro switch on the bar that the print head slides along, check this isnt stuck
Posted on Jul 09, 2009
    Problem Solver:
  • 9 Answers
Im having the same problem they told me to try and reinstall the driver if it still doesnt work the drive belt is burnt out cost to fix $500-$600 includes shipping parts n labor
Posted on Aug 24, 2008
Double printing on page
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the double printing occurs before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Dec 29, 2010 | HP LaserJet 2420 Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Jan 22, 2010 | Brother MFC-7820N All-In-One Laser Printer
Paper feed problem
With that many labels I would replace the paper feed roller, RL1-0266-000, about $8.00
it will save you lots of headaches and a spare will fix it next time it happens.
Sep 01, 2009 | HP LaserJet 1022 Printer
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Feb 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Disc Feeding Problem
I am assuming you are using a PF-2 printer. If you are using a standard HP78 ink cartridge instead of the Microboards cartridge, the unit will only print approx 5 discs before it stops. The microboards cartridges have a security tag under the barcode label that is scanned by a magnetic reader on the left hand part of the unit. If you are careful, you can use a razor blade and remove the label from a microboards cartridge and tape it on the front of a HP ink and save yourself about $25 an ink cartridge...
Nov 29, 2007 | MicroBoards PF-2 InkJet Printer
MicroBoards PF-2 InkJet Printer Logo
410 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
