Question about Refrigerators
I noticed water inside my LG (Model No. LRTPC1831W) frdige. I think there is aleak inside the fridge. How can I fix this problem?
  • 481 Answers
The water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 20, 2008
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
I own a lg ice beam door cooling fridge for the past five years since recently the fridge is not cooling properly when i open the firdge i see the fan inside the frdige is at standstill pls advice also the...
sounds like u have a deforst problem. if it dont automatical defrost then u have to manually do it then u will have to replace the defrost timer and hope your defrost heaters are still good. ok
Feb 12, 2011 | Refrigerators
I have a Electrolux Frdige Freezer Model ERF 2830.
check appliance blog .com and type in your make/model,sometimes there are fixes on there
Nov 01, 2009 | Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
