Question about Frigidaire GLMV169D Microwave Oven
Squeaks the glass carousel squeaks...its driving me crazy...help
  • porsche838 Mar 22, 2009
    I have the same issue. Its not coupler or motor; the noise comes from the support wheels for the glass turntable.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
    It may be the turntable motor or coupler.
    You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
Fixing majic chef carousel
The part your going to want is called a stirrer motor.This is a DC motor that causes the glass to turn inside the microwave, and also helps distribute microwaves inside the machine to help heat properly. To access this part you'll have to remove the bottom of the microwave. Its only held on by two screws.
May 17, 2012 | Magic Chef Microwave Ovens
My kitchen aid microwave makes a loud crackling noise every once in awhild
Is it a carousel (turning platter)? if it is, than it is probably dirt on the platter support wheels and the platter support groove/track on the bottom of the oven, clean the glass plate, the support wheels, and the bottom groove as well, if you want to make sure the crackling comes from the carousel system, take it all out (support and platter) than place a glass of water in the oven and start it, if there are no crackling noise than my theory is correct, if the noise is still there than have it checked by a professional technician...
Sep 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Thanks! just solved 2 of my westinghouse microwave problems from your site. Last question: the glass carosel squeaks as it goes around. Bought microwave @ garage sale - so maybe food leaked down...
It is more likely one of the little wheels is not turning causing the squeek. You might want to take the glass off and check the little wheels, because it will eventually cause a problem with the drive motor.
Aug 15, 2011 | Westinghouse WST3504 Microwave Oven
I have a Sharp carousel R 9330. I need the 15 inch revolving clear glass tray that goes with it. Mine broke after over 15 years of use. Where can I find a glass tray for it?
That is part number NTNT-0036MRF0 (those are zeroes, no ohs) and you can order it from Encompass here.
Jul 08, 2011 | Microwave Ovens
Sharp Carousel convection/ microwave. The turntable/ motor coupling has broken where can I buy one? I live in White River Mpumulanga.My e mail adress is richardtaggart@msn.com
Looks like you have the purchase the glass tray in order to get the coupler. I would give Reliable Parts a call though phone # is 1-800-666-0313. Give them your model number and the name of the part you need.
Nov 29, 2010 | Sharp Carousel R530EST Microwave Oven
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Plastic peice that fits under plate inside micowave that makes it rotate
If the model number you have this question listed under is correct, there are two possible parts based on your question. There is the carousel ring, that turns the glass tray, and there is the small plastic coupler that the center of the glass tray is supported by. The part numbers are as follows:
Carousel ring - WB06X10513
Coupler - WB06X10564
You can view and excellent exploded view diagram of this microwave at pcappliancerepair.com. The parts I mention are listed under Diagram 1151005 as items 84 and 101 respectively.
To replace the coupler, you simply remove the glass tray and gently pry straight up. The coupler will pull off of the turn table motor shaft. Insert the new coupler and press on to the shaft.
If this is not the correct model number, please post back with your correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
I have a sharp carousel microwave(1997}. model#r-220aw serial #120115. i broke the glass carousel plate. where do i find one?
The tray is Sharp part # NTNT-A011WRF0 or NTNT-A034WRE0. (Same part, just different numbers).
Here's the link to where you can find it...
www.microwaveglasstrays.com
Jun 25, 2008 | Sharp Microwave Ovens
Frigidaire GLMV169D Microwave Oven Logo
252 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
