I have a Samsung HLR4677WX/XAA, 46" DLP that looses picture, but not sound, when I use a HDMI cable. I do not have the problem with HD RCA jacks. I originally thought it was my DVD player, but I have changed players and still experience the same issue. I have upgraded my choice of entertainment viewing liquor, so we can eliminate that as well, thanks.
  • dsrgroup Mar 13, 2009
    any more solutions here? could it be 2 different versions of hdmi not communicating?
    Champion:
  • 217 Answers
Check to see if the lamp is still on in the back of the tv after losing video, if so probably the dmd board or digital board
Posted on Jul 20, 2008
Samsung dlp has static
I have seen this happen quite a bit. For some reason the input (cable jack) works loose from the board. I would try running your source signal (cable/dish) to another input on your tv...such as S Video/HDMI/Composite or whatever you have available.
Jan 07, 2013 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR56 DLP has HD, DMI and sound but all SD is green with lines
I have a Samsung HLR56 TV with the same problem. I am guessing the problem is the lower board you mentioned and am considering buying one so I can replace it. www.shopjimmy.com might have it so if I order it I will try it.
Dec 12, 2012 | Samsung DLP HL-P5663W 56" TV
Have hln617wix/xaa all inputs hdmi rca ok vidio good cable or antena picture all scambled
The DLP does not have a flyback but if rear inputs work hook cable b o x there via audio/video cables or use a VCR (does not have to play tapes) via its av jacks to one set on back of tv.
If Video rear inputs are good but antenna,coax are not B Y P A S S the problem.
Mar 17, 2012 | Samsung Televison & Video
Is it possible to replace the HDMI input connector of my Samsung LNR408DX/XAA? What is the exact name or code/type etc for replacement of the HDMI female connector of my Samsung LNR408DX/XAA? I seem to...
Re soldering the sockets connections on the pcboard will normally fix this problem. It is unusual to require a socket but possible. Sockets are available through a good electronics outlet, depending on your country.
Dec 27, 2010 | Televison & Video
I cannot tell the difference between my SD channels and my HD channels. I have samsung DLP tv, HD cable box and bose theater system. I am using an HDMI cable but there is not difference between that and...
In most cases you will not be able to see a great difference between HDMI and Component connections. As far as not seeing a difference between HD and SD signals from your cable box, go into the settings of it and see what resolution it is putting out. If you have a Motorola cable box, with it off and the TV on press the menu button and the setup screen will appear. That will tell you the output resolution as well as what the 4:3 override is set to. Please take a few moments to rate my answer. Thanks....
Nov 22, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
When my ps3 is plugged into my samsung hln467w with an auvio hdmi to dvi cord there is no sound.what should i change so that i have the nice picture with sound?
Audio is only carried on HDMI and not DVI. You can get video only with this type of cable. HDMI to HDMI would work but not HDMI to any other connector. You can run a seperate dual RCA (red and white) to your system to get audio.
Nov 10, 2009 | Samsung HLN467W 46" Rear Projection HDTV
RCA 46" LCD TV - HDMI Stopped working overnight
I don't mean to sound ignorant, but can I assume you have already checked your Source Selection just incase someone hit a different button on shutdown ?
Sometimes when I just set the remote down can sometimes change a setting on the TV, I thought maybe the same may have happened to you too.
Jun 03, 2017 | Televison & Video
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Connection between Samsung 46" LCD / Samsung Home Theater System &Tivo
None of the cables you mention are HD. Does your box have a HDMI out? If it does, an HDMI cable is what you need if your tv has an HDMI input jack.
May 13, 2008 | Televison & Video
Samsung Rear Projection DLP HDMI Captions
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Nov 29, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
