Question about Panasonic KX-TG1033S Cordless Phone
Static on line
When I place a phonecall, several seconds elapse in which I hear only static before the called number starts to ring. Possible cause?
    Problem Solver:
  • 22 Answers
Does the static stay on the line after the called party answers?Is the static on incoming and outgoing calls on any phone?if the answer is yes to the above questions,check your house jacks for corrosion.There are a number of things that can cause static inside your house and outside.From the interface box on your house where the wires come from a pole or from under ground is phone company problem.From the box into the house is your problem,so the easy solution is to make the phone company come out and determine from what side the static is coming from.There is usually no charge for this unless you have them come into your house if the problem is there.
tk46
Posted on Jul 20, 2008
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
How do I get caller display for which I pay BT extra to work on my handsets when it works fine on the landline on my property. I have checked Blocked calls list etc but still get No Number displayed i
Do you have DSL on the same phone line? I have seen where the 58 GHZ phones sometimes are not compatible with it because of the WiFi being on the same freq. and thus stop the CID signal from coming thru. There also might be a distance issue or some type of filter on your line causing the trouble. The CID signal is sent thru between the first and second rings of the phone. So if you can get a phoneman's headset and connect it to the line to listen when the phone rings, you should hear a kinda static between the first and second rings. If not then you aren't even getting the signal to the phones.
Apr 23, 2014 | Vtech CS5111 58 GHz 1Line Cordless Phone
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
On incoming calls rings once then stops then person calls again comes thru. also after talking sometime u can hear the system dialing? there are 7 phones in the house one has the FWD light on? could...
The first symptom of an incoming call ringing once then stopping is called trip and ring which is caused by a partial short on the phone line. The second symptom is called crosstalk caused by the two phone lines being shorted to each other. The service provider is most often the cause of these troubles. Often this type of trouble happens during wet weather or shortly after. The third symptom of static on the line cna also be caused by the same conditions. All three symptoms are likely caused by the same trouble from the service provider. Advise you report the trouble to your service provider.
Dec 09, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Unable to make or receive phonecalls
Your phone is barred. This means it has been blocked of making or receiving any calls.
Aug 18, 2007 | O2 Xda Orbit Smartphone
Lots of static heard during use of this phone.
Time for a new phone. Most likely there are some bad solder connections and they could be anywhere. A 2 year old battery should not cause such severe problems so I'd spend the money on a new phone before a new battery.
Jun 27, 2007 | Motorola Mobility MA580 5.8GHz Digital...
Panasonic KX-TG1033S Cordless Phone Logo
594 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
