Would like to put protection on second computer
  • Lee Eismann May 11, 2010
    What kind of protection are you referring to? Do you want to install a firewall and antivirus software?
    I will need your operating system before I can recommend any free software to you.
    Scholar:
  • 191 Answers
There are free antivirus available over the internet try
antivir
http://www.free-av.com/
Posted on Jul 20, 2008
How do i get past K9 bluecoat protection in Second Life login? it says im blocked by the Site or whatever it is...
whoever put the K9 web protection on your machine will have the password to either uninstall it or create an exception for 2nd life. otherwise you will not be able to play the game.
Feb 19, 2015 | HP Pavilion Computers & Internet
How do i install mcafee total protection 2014 on a second machine?
If you have the license for just one computer, you won't be able to install it on a second computer. If you have multiple licenses, you can log on to your McAfee account from the computer you want to install it on, and download the setup and follow on screen instructions to install it. You can login to your McAfee account on this link:
https://home.mcafee.com/Secure/Protected/Login.aspx?rfhs=1&ctst=1
GuruAid
Jun 21, 2014 | Computers & Internet
Unlock memory card
every card you put in a card reader should be visible on your computer. You should be able to download the pictures from the card to the computer. If you can't see the pictures on the computer, perhaps you pressed the key symbol with every picture, or you made them read only in the camera menu.
To remove protection from all images in the folder or folders currently selected in the Playback folder menu, press the AE-L AF-L and bin buttons together for about two seconds during playback. So no pictures in the folders are protected anymore.
Also check you did not put the lock switch in the down position (LOCK) The switch on the left should be like on the 64GB card.
Not like the 32 GB card.
Jan 31, 2014 | Nikon D3100 Digital Camera
2005 Victory Vegas, Motor lost power when cruising about 65. I thought a plug went out, but the plugs seem fine. Running like on one cylinder but both are working but power is gone. not idling right...
It sounds like computer has put you bike into limp home mode or safety mode to protect the engine. What warning lights do you have if any come on? it sounds like a sensor has either malfunctioned or has done its job properly and picked up something wrong like, temp sensor, oxygen, oil pressure, mass air flow sensor etc. Either way when something is out of the norm form the sensor inputs to the bikes computer it will often limit the revs on the bike putting it into limp home mode to protect the engine.
I personally would be getting a mechanic to put it on a diagnostic machine. If the computer has caused the bike to go into limp mode, your mechanic will more than likely be able read a fault code from your computer to point you in the right direction as to the root cause of this fault.
Jun 02, 2011 | 2005 Victory Vegas
Protect mode??
Check your speaker wire and terminals at the speaker, it's shorting. The receiver goes into protection to keep from causing damage to itself.
Jul 04, 2009 | Kenwood KVT-512 Car DVD Player
Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me. Here is the first one 1.)go to MY COMPUTER 2.)right click on MMC drive 3.)click on eject. 4.)remove MMC form card reader 5.)again put it back (if at once it didn't worked try again step{2,3,4}
second method is: sometimes your USB port locks it try some other USB port & then put the MMC in memory card. pls rate me thank you
Feb 14, 2009 | Nokia N72 Cellular Phone
Took pictures with Panasonic DMX-FZ50 using a Lexar SD 2GB memory card. I put card into card reader in my computer to upload. It shows a JPEG thumbnail with a file # and if you place the cursor over it, it...
Firstly, whenever you put the media card into a card reader, ALWAYS turn write-protect on, to protect the images already on the card.
Secondly, AFAIK, the only way that your computer could have 'wiped' the card is if you told it to Move the images, rather than just Copy them. Again, setting write-protect would have solved this.
May 04, 2017 | Cameras
No more Pics in INDIA!!!
Hello ommikeom !!
  Firstly i like to tell u to do a hard reset.Remove the batteries and kepp pressed your power button for few seconds and then replace ur batteries and then give a try. If it dint work reply me..
Regards
Smilemaker
Jun 16, 2008 | Olympus Stylus 710 Digital Camera
How to remove write protect on my usb flash drive
how to remove write protected on my usb flash drive and i have mp3; when plugin into the usb hub it shows a problem occured during installation
May 04, 2008 | Electronics - Others
Processor fan
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Mar 18, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
