Question about Gateway 2520915 Keyboard
Gateway cordless KR-0401 Keyboard
I'm having a hard time logging into my computer because there seems to be something wrong with the keys. When I try to type in my password, only certain keys are working. The delete and backspace keys aren't working either. They are both typing characters. I've been playing with the keyboard for almost 2 hours and can't seem to figure it out. Please help!!!
  • l_jerry Dec 19, 2008
    Need information on setting the keyboard and mouse (cordless)
  • Anonymous Dec 25, 2008
    CAN TYPE ANYTHING
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
Posted on Jan 20, 2009
Thank you so much!!!! proph37, you solved my problem, I was not pressing the connect button.
For those out there with a cordless Gateway keyboard who are having trouble getting the keyboard to work: First, make sure the batteries are ok, second, press the connect button on the back or side of the keyboard, third, press the connect button on the little black thingy.
Posted on Apr 04, 2009
My Gateway laptop keyboard stopped working. Any
one if the key bored is wireless resync it. if it is not make sure it is plugged in fully if not plug it in and restart your computer. hope this helps.
Jun 30, 2010 | Gateway 2520915 Keyboard
Gateway model KR-0817 WILL NOT TYPE I HAVE TO USE THE ON SRCEAN TO TYPE
Make sure the keyboard's "tail" is plugged-in to the _keyboard_ slot on the motherboard.
Try the keyboard on another computer, to see if it works at all.
Connect a "known-working" keyboard to your computer, to see if _any_ keyboard works.
Try a keyboard with a USB "tail".
Jan 22, 2010 | Gateway ML6720 ML6721 ML6725 Keyboard...
I can not log onto the computer - some keys will not work......
The Keyboard is defective or going bad on you. Switch out the keyboard with a known working one and you will see a big difference.
If your using a keyboard with a ps2 connector, get a keyboard that uses usb, those seem to be more reliable cause the ps2 connectors wear out quicker.
Jun 21, 2009 | Gateway Computers & Internet
My keyboard is not working!!?? :(
yikes it seems as if the keyboard themselves are damaged and need of replacement though you maybe able to use a USB plugged keyboard (or PS/2 keyboard if supported) but it does seem those keyboards are ruined
Mar 14, 2017 | Gateway 2520915 Keyboard
Moved my GATEWAY KR-0401 wireless keyboard & now won't work!
  1. Check and see if batteries are in keyboard and that they are still good and working.
  2. If the batteries are good and ready to go then make sure that the adapter for the wireless keyboard is plugged into the correct USB port in the back of your computer and that it's working.
  3. If none of the above works then what you'll need to do is go buy a wired keyboard and attach that to your computer and log into your account and find out what's going on with the wireless keyboard. Once you have figured out what is going on with your wireless keyboard then you can take the wired one back to the store and continue using the wireless keyboard. If I were you though I would keep the wired one around just in case.
Apr 08, 2009 | Computers & Internet
I would like to sync a Logitech cordless desktop MX3000 to my gateway computer. my orginal keyboard has some damage and some keys are disabled. Also, do i need other components to permit a Gateway computer...
you should be able to plug in the new keyboard and mouse combo and reboot and be ready to go save for some drivers that muight get you some extrensive extra features
Mar 24, 2009 | Computers & Internet
Logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Dec 01, 2008 | Logitech 967437-0403 Keyboard
Cut, copy, and paste keys
You may want top try this? I did not work for me but with some luck and hope it works for you.
http://support.gateway.com/s/issues/2-1889658510.shtml
Best of wishes and take care!
Jun 07, 2008 | Gateway 2520915 Keyboard
Keyboard beeps when any key is pressed
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
Jun 25, 2007 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
1,691 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
